RV.Net Open Roads Forum: Tech Issues: Best Fuel Preservative for Pure Gas ???
 > Best Fuel Preservative for Pure Gas ???
Page of 5
jplante4
Cape Cod
Posted: 12/15/19 06:40am Link  |  Quote  |  Print  |  Notify Moderator
rk911 wrote:
in case it makes a difference to you AvGas is low lead not no lead...fyi
I pump a lot of 100LL this time of year into 5 gallon containers. Just a warning; if you have a Honda engine, it's ok to use 100LL to store it, but don't run more that a tankful through the engine. The valve clearance on Hondas is tight enough so you'll get lead buildup and a stuck valve.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
Airdaile
On The Road
Posted: 12/15/19 06:45am Link  |  Quote  |  Print  |  Notify Moderator
YouTube channel Project Farm does a lot of comparison videos.
Cobra21
minnesota
Posted: 12/15/19 06:51am Link  |  Quote  |  Print  |  Notify Moderator
Johnny G1 wrote:
Bobbo wrote:
Seafoam for me, and I always buy 91 octane ethanol free gas for my small engines.
X2 for me, Shell 91 and 1 oz seafoam per gallon, no more small engine problem's.
This is the way to go. And I use Seafoam or stabil to neutralize any moisture or condensation my gas can may aquire. I never drain or run dry any of my small engines.
Brian
Oasisbob
Portland Oregon 97266
Posted: 12/15/19 08:52am Link  |  Quote  |  Print  |  Notify Moderator
I use STA BIL in all my small engine units. Cheap insurance. I also date my gas cans. I was surprised to find fuel three years old.
Oasis Bob
Wonderful wife & 4 Really Fun kids
2008 KIA Sedona 3.8L 24 valve V-6
2001 Bantam Trail Lite B-19
HAPPY TRAILS">
Cummins12V98
on the road
Posted: 12/15/19 08:54am Link  |  Quote  |  Print  |  Notify Moderator
Brian
Are you using "pure gas" ?
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
on the road
Posted: 12/15/19 08:55am Link  |  Quote  |  Print  |  Notify Moderator
noteven
Turtle Island
Posted: 12/15/19 08:56am Link  |  Quote  |  Print  |  Notify Moderator
Gasoline will store very well in sealed containers. Gasohol (ethanol blend at the pump) stores reasonably well in sealed containers, or a closed fuel injected system, but not worth the risk. The trouble comes from air with water vapour getting to the gasohol like in a carburetor system.
If you have a small engine that absolutely must start when you need it - your cold weather emergency generator, the jaws of life pump on your fire truck or that dam chain saw or weed whacker - you can use synthetic gas like Aspen gas which has a 7 or so year shelf life. It is available straight or premixed for 2 cycles. It is safe in all engines. . It is not cheep.
winniman
muskoka Ontario
Posted: 12/15/19 09:17am Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
"To those that don't understand, this not premium gas, but Non-ethanol gas"
I think most have no availability or no clue what truly "NON" ethanol gas is!
Buy mine at CENEX a local Farm CO-OP.
In Ontario, most petro stations don't have ethanol in their premium. You are right though, the non ethanol is the key. I just prefer premium because Im sure the higher octane helps when sitting as well. For all the gas I use in my lawn mower, chain saw, and weed eater, its no big deal. My boat has a 70 gallon tank. I will run regular for most of the season, then switch to non ethanol for the last two or three tanks at the end of the season. I add stabil for the last trip as well.
jjrbus
FT Myers FL
Posted: 12/15/19 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
They, whoever they are claim that non ethanol gas has a 1 year shelf life, so I need no stabilizer. Since I started using non ethanol all my small engine carburetor problems have ceased.
For my Honda 2000 I run it on what is available when traveling and the last tank is always non ethanol. I do try to run things dry when putting away, bud does not work that way in real life.
Non ethanol is common here in Fl so I buy in small quantities, a 2 gallon can never sits for more than about 4 months.
Dave H M
IL
Posted: 12/16/19 05:49am Link  |  Quote  |  Print  |  Notify Moderator
jirbus, maybe your Honda has a carb drain, my Champ did. That gets all the gas out of the carb.
Page of 5
