RV.Net Open Roads Forum: Class A Motorhomes: Coach/chassis battery replacement
 > Coach/chassis battery replacement
two travelers
Smithtown, NY
Posted: 12/15/19 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
Batteries in our coach are at least 6yrs old. I'm thinking it might be proactive to think about replacing them. Have tested them with one of those testers where you suck up water from each cell and all seemed ok. I keep them on a trickle charger when not in use. What is the typical life of these batteries? Any suggestions on what brand to replace them with?
sundancer268
Charlevoix
Posted: 12/15/19 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
I got over 8 years out of my Interstate 6 Volt Flooded Batteries. I replaced the two 6 Volt batteries with 4 LifeLine AGM batteries and relocated them to the inside of the coach. I wanted more capacity and the original battery compartment would only hold two batteries.
U. S. Navy (RETIRED) 1993
1995 Gulf Stream Scenic Cruiser 34' Diesel Pusher Cummins B5.9 12 Valve Engine, Allison MD-3060 6 Speed Transmission.
TOAD: 2019 Jeep Cherokee Trailhawk Elite
Road Master Sterling All-Terrain, Airforce One
midnightsadie
ohio
Posted: 12/15/19 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
it all comes down on how you camp.. if you boondock alot, get agm,s if your plugged in 75% of the time all you need is two marine deep cycle batteries from wal mart. and I think its time ,mine last about six years very well maintained. one day it just died.
near Jawbone Canyon, CA
Posted: 12/15/19 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
Since I don’t want to replace on the road, I replace at five to six years.
jplante4
Cape Cod
Posted: 12/16/19 04:55am Link  |  Quote  |  Print  |  Notify Moderator
I have 4 years on my Interstate GC2s and I have 2 with a bad cell. My fault - I had a bad solar controller that overcharged them over the winter. I expected to get 5 years.
Make sure the batteries are at rest (not charging or discharging) when checking the specific gravity. If the specific gravity is still within limits, keep 'em.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
Wherever I happen to park
Posted: 12/16/19 05:09am Link  |  Quote  |  Print  |  Notify Moderator
I got 9. but 7-10 is considered normal.
Now.. in my case chassis went first so I used the BOOST (emergency stat on my rig) to crank 'er up then pulled the battery and off to DEKA store.. One new DEKA later I was back in full service.
Then the house died a couple months later and I drove to the DEKA store and got slightly bigger (230 amp hours instead of 220) the added 10 AH meant I could not lift them onto the battery tray. had to have the store staff help.... DEKA batteries are 100% Made in the USA by the way. No overseas content.
Home is where I park it.
rgatijnet1
Posted: 12/16/19 05:20am Link  |  Quote  |  Print  |  Notify Moderator
I think a lot depends on how you travel. I mean batteries are readily available all over the country so unless you like to boondock out in the sticks away from civilization, I would wait until your existing batteries die. If the house batteries go bad it is really no big deal if you are plugged in to shore power when you travel. If your chassis batteries go bad, you can use your boost switch and still start your engine to take the coach to a place to change the batteries. Who knows, you may get another year or two or three out of them. [emoticon]
Sam Spade
North Central Florida
Posted: 12/16/19 07:11am Link  |  Quote  |  Print  |  Notify Moderator
That is a specific gravity test and will usually NOT give a clue as to overall battery health.....just state of charge.
And I hope that you are NOT using a "trickle charger" but a smart automatic tender type battery maintainer.
Battery tenders are GOOD.
Trickle chargers.....not so much.
Wet cell batteries can last well beyond 5 years if well cared for and not exposed to a lot of heat.
I think you should base your decision on "How much of an inconvenience will it be if one fails while out camping."
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
IB853347201
Eastern Ontario
Posted: 12/16/19 07:27am Link  |  Quote  |  Print  |  Notify Moderator
On average I replace mine in our MH every 6 years.
Touring in our 2010 Suncruiser, beaches, site seeing, national parks, chillaxing..
garyemunson
Reno, Nevada
Posted: 12/16/19 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
The best thing to help maintain 6 volts are the automatic watering systems. So easy to be sure the water is at the correct level.
