RV.Net Open Roads Forum: Tech Issues: Modified/pure sine wave
 > Modified/pure sine wave
tarnold
georgia
Posted: 12/17/19 05:04pm Link  |  Quote  |  Print  |  Notify Moderator
Op, not gone. Original post started mistyping converter/inverter. I do know the difference. Just wasn’t thinking all the way thru. As originally posted will NOT change current configuration anytime soon. ASV was a little over $4k (mostly paid by insurance) and the O2 was $2500 not paid by insurance, our choice. Expensive stuff and needs to be cared for. Will ponder some more.
BFL13
Victoria, BC
Posted: 12/17/19 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
It would help us understand what size inverter you need etc, if you could provide the 120v intake power specs for the two medical equipments, and for how long you will need to run them before there is a chance to recharge the battery bank the inverter running them is on.
That is if you don't run them on 12v.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
Morro Bay, CA
Posted: 12/17/19 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
Spend $250 to $350 for a pure sine wave inverter and move forward. Isn’t worth all this fuss!
2oldman
Ca
Posted: 12/17/19 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
tarnold wrote:
Op, not gone.
Thank you.
mikestock
Vestavia Hills, AL, USA
Posted: 12/17/19 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
I would not go to the expense of replacing the MSW inverter with a PSW unless you can see some future need for PSW. I go along with a small PSW just to handle your current needs. You could probably do a free standing, independent, source for the ASV and save quite a lot.
I installed a Whirlpool, residential refrigerator and the installer said he has installed several in motorhomes with Xantrax, MSW without problems. After burning up an electronic board and almost a second I installed a 2.5kw PSW Xantrax. No more problems. I wouldn't have spent the $1500 if I only needed 150 watts, or so, of PSW.
The installer, who I saw recently, says he now advises people, after my fiasko, not to use the Whirlpool with a MSW inverter. I learned the hard way but the installer stood behind his install and replaced the fridge without cost to me.
BFL13
Victoria, BC
Posted: 12/17/19 05:50pm Link  |  Quote  |  Print  |  Notify Moderator
That's the whole thing. Without knowing the specs of the medical equipment the OP will use, you can't know the inverter size and then whether it can be done on a smaller independent PSW inverter or if it would be worth swapping out the bigger MSW inverter for PSW one.
Also for time to run it all, if he needs more battery bank and how to recharge that.
Morro Bay, CA
Posted: 12/17/19 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
“I would not go to the expense of replacing the MSW inverter with a PSW unless you can see some future need for PSW”
Yay are kidding, right? What sensitive electronic item does NOT require PSW, Mike?
pianotuna
Regina, SK, Canada
Posted: 12/17/19 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
Hi all,
The company replied to my query:
"Hello,
Thank you for contacting me. The item have separate battery, carrying bag and trlley?12V rechargeable Lithium-ion battery. It is more convenient to use at outdoor.
If you have other questions please let me know.
Have a nice day."
I think that means it can be used on 12 volts which would be good from a power savings point of view.
https://homecarewholesale.com/products/o........le-oxygen-concentrator-homecarewholesale
Regards, Don
tarnold
georgia
Posted: 12/18/19 06:01am Link  |  Quote  |  Print  |  Notify Moderator
Op, both units have large bricks. The reperonics ASV and the O2 each require 2amp. So 7 hrs at night. Installed 2 new 230amp 6volts yesterday.
wanderingaimlessly
SOBOVA
Posted: 12/18/19 06:17am Link  |  Quote  |  Print  |  Notify Moderator
OP can you give all the data from the bricks?
Output voltage and watt or amp rating.
It looks like the ASV uses the same "brick" 80 watt transformer across most of their BiPAP as well as the DreamStation ASV unit.
DW has the dream station without the ASV and we have a 12 volt cord that powers hers straight from a cigar lighter style plug in the camper.
Your unit is more particular, and here is what appears to be the right 12 volt supply
shielded 12 volt supply
At that price point, using a PSW large enough to handle both the asv and the separate O2 concentrator would likely make more sense.
* This post was edited 12/18/19 06:45am by wanderingaimlessly *
