RV.Net Open Roads Forum: Refrigerator question for you class A campers
 > Refrigerator question for you class A campers
steveandjil
Southern Arizona
Posted: 12/18/19 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
We have had a Winnebago View class C for about 5 years, and a 5er for the decade before. We think at times of a larger class A for part timing in retirement. Many have commercial refrigerators. How do you keep your food cold when camping in a no hookup CG such as a national park. Can’t run the generator 24/7.
Thanks,
Steve
Steve Schwartz
2015 Winnebago View
ScottG
Bothell Wa.
Posted: 12/18/19 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
Lots of batteries and I think you mean residential, not "commercial".
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
steveandjil
Southern Arizona
Posted: 12/18/19 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
Yup meant residential. So the batteries are just run through a big inverter I assume. Can you go a day between generator runs in hot weather?
ScottG
Bothell Wa.
Posted: 12/18/19 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
Sure - with enough batteries [emoticon]
Mojave, Kern County, California
Posted: 12/18/19 09:19pm Link  |  Quote  |  Print  |  Notify Moderator
Why think only about a generator? Solar recharging isn’t experimental or a toy. Most days you’ll be completely recharged with adequate system...batteries, controller, solar panels and properly sized wire. Start with an energy survey to determine your amp hour needs.
Dale.Traveling
Newport News, VA
Posted: 12/19/19 03:23am Link  |  Quote  |  Print  |  Notify Moderator
Thanks,
Steve
A battery bank properly sized to support the house loads for 24-36 hours, energy conservation, a few 100 watts of roof solar helps reduce generator dependency, generator use to recharge the bank in the morning and evenings.
2006 Hurricane 31D built on a 2006 Ford F53
Bruce Brown
Northern NY
Posted: 12/19/19 04:44am Link  |  Quote  |  Print  |  Notify Moderator
Today's modern refrigerators use so little electricity compared to the older ones it seems to not be an issue for most.
A few years ago I put a new cooling unit in our LP fridge. If I were doing it again I'd just put in an electric one.
We recently did that in my buddies off-the-grid hunting camp. The new electric with limited generator usage works much better than the propane one we took out.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
wildtoad
Blythewood, SC
Posted: 12/19/19 04:59am Link  |  Quote  |  Print  |  Notify Moderator
You planning on being out in the Arizona sun in the summer and run fridge on batteries? You OK inside a MH with no AC?
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Wherever I happen to park
Posted: 12/19/19 05:33am Link  |  Quote  |  Print  |  Notify Moderator
I have a RV type "Absorption cooling unit" (Refrigerator) this uses HEAT to Cool believe it or not so it can run on electricity (About 325 watts in my case which is not at all efficient) or Propane.. ONly moving parts are the gas valve and fluids inside the cooling unit (Gas and liquid) Just put a new cooling unit on it after 14 years and change last Oct. (OUCH).
Now it does use 12 volts for control and ignition but it can run a long time on a full tank of propane and a full battery bank.
I also have a 2nd Freezer. this is one of the high efficiency Compressor units (Engel) Both Dometic and Norcold have offerings in this class. Mine is a chest freezer and draws a great whomping 36 watts (3 amps at 12 volts) when running. I have over 500 amp hours of battery so you get the "how long". Even a single pair of GC-2 (220 amps hours) around 3-4 days
At one time both D and N had full size RV refrigerators using this technology but I'm finding them harder to track down now.. 35-45 watts the compressor is what I call a Danfoss class (look it up) may be a Danfoss or a competitor's but that class.
However when on the move.. I burn propane.
Home is where I park it.
DutchmenSport
Indiana
Posted: 12/19/19 08:08am Link  |  Quote  |  Print  |  Notify Moderator
If you have an all electric residential refrigerator in your camper and don't have shore power, the only way to keep the refrigerator running is with an inverter and a battery bank, or else the refrigerator is plugged directly into a generator.
In our world as it exists today, you have two methods to keep your batteries charged; solar or generator.
If you don't run your generator to keep the batteries charged, solar is the only other method. Pick your method: generator or solar. There's really no other short-cut.
