RV.Net Open Roads Forum: General RVing Issues: Awning Cost
 > Awning Cost
1L243
Oregon
Posted: 12/19/19 12:49am Link  |  Quote  |  Print  |  Notify Moderator
Anybody have a idea of what it would cost to ad a 10' electric awning and installation? This would be in addition to the awning I already have. The channel for the vinyl fabric is already there.
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
lakeside013104
North America
Posted: 12/19/19 03:10am Link  |  Quote  |  Print  |  Notify Moderator
This will give you a place to start looking:
https://www.campingworld.com/outside-rv/awnings-canopies-shades/rv-awnings
or
Same link
Good luck
Lakeside
DutchmenSport
Indiana
Posted: 12/19/19 05:53am Link  |  Quote  |  Print  |  Notify Moderator
We had a second awning installed on our 5er a year ago. We scheduled the work with our dealership. We also had some other warranty issues, and wanted a minor repair done.
The biggest challenge for the dealership service department was how to run the wire to power the awning. And then, where to run the switches. We also had LED lights installed.
They did a great job running the electric wires that powered everything, and everything went through the fuse box/converter too. Because we wanted the awning over the back door (which is on the opposite side of the trailer), we wanted the switches near the back door. They ended up putting the switches in a cabinet in the bedroom, but near the door and a window on that side too.
The total price for the lights, the awning, the labor, and replacing the little amber porch light with a different LED light, because the awning interfered with the original light ran us about $2000.00
Was it worth it? Absolutely YES! We use the back door on the opposite side as our main entry door a LOT more than the front door in the normal location.
When camping, the normal front door is the "front". When home (and we use our 5er 24x7x365), the back door on the opposite side is the "front". The back door gets used a LOT more than the traditional front door. A lot!
So, the price of the awning and lights was worth every penny for us.
EDIT:
FYI, the added 2nd awning is 16 foot long too.
* This post was edited 12/19/19 06:02am by DutchmenSport *
rockylarson
Jersey Shore
Posted: 12/19/19 06:05am Link  |  Quote  |  Print  |  Notify Moderator
Solera !8 volt awning CLICKY
We got the basic 16 foot 18volt for 1,200$ installed.
They make a wired option with all the upgrades.
Jan and Rocky
Volunteers for USFWS. 25 refuges with 8000 hrs ea since 2006. 2004 Allegro 30DA, Workhorse 8.1, Banks, 2012 Jeep Liberty Jet, Blue Ox Aladdin, Brake Buddy Advantage Select, 300 watts solar, 5 Optima group 31 AGM's, 2000watt Ames PSW inverter.
Lynnmor
Red Lion
Posted: 12/19/19 07:33am Link  |  Quote  |  Print  |  Notify Moderator
Before you start, do you know for a fact that there is framing or plates within the wall to mount the awning?
Manual awnings were attached at floor level and didn't need attachment points half way up the wall.
Gonzo42
California
Posted: 12/19/19 08:11am Link  |  Quote  |  Print  |  Notify Moderator
We used Shade Pro to upgrade our worn manual awning to one with power actuation and aluminum weather shield, which was done in our driveway at a reasonable cost. If they are in your area you should check them out.
MOTHER SHIP Winnebago View 24H (2007 Dodge Sprinter 3500 Chassis, 2008 Body)3.0 L M-B Diesel V6 bought used with 24K miles. Toad: ROCKY the Flying Squirrel.
SamanthaNichols
2046 Hillcrest Drive Tacoma, WA 98402
Posted: 03/25/20 06:05am Link  |  Quote  |  Print  |  Notify Moderator
I installed a medium awning 3 months ago at a price about $1000 for type of RV awning is slide out. If you want to install an automatic awning , the price is more expensive from $2000 to $3500 depent on size.
BarneyS
S.E. Lower Michigan
Posted: 03/25/20 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
Check these out.
Barney
Not towing now.
 > Awning Cost
