RV.Net Open Roads Forum: Truck Campers: Propane smell
 > Propane smell
mattyj
Long Island.New York
Posted: 12/19/19 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
Hi, I am Puzzled I removed the regulator and both horizontal lpg tanks and the camper still smells like propane! Does anybody know what could possibly be the cause of this? Thanks,Lou
2006 Ford F 350, 6.0 PSD 8 Foot Bed 4x4 with Torklift Tie downs and Stable Loads 2004 Lancelite 835 ,a/c ,electric jacks , conveince/all weather packages
Buzzcut1
Norcal
Posted: 12/19/19 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
BBQ grill in a compartment?
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 08 Lance 1055, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
NEOK
Oklahoma
Posted: 12/19/19 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
The odorant put in propane so you can smell the gas is very strong and will tend to hang around anything it is close to such as your propane storage compartment.
neok
2009 GMC 25000HD Short Bed 6.0 Gas Engine Crew Cab SLT 4x4
2008 Bigfoot 15C9.5FS
Torklift Talons, Fastguns, Stableload Quick Disconnects, Superhitch & SuperTruss
monkey44
Cape Cod, MA and Central Fla
Posted: 12/19/19 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
Open all windows and vents, open cabinets ... turn all vent fans on for a couple hours overnight if its convenient. Then close it up for a few hours, or overnight. If it smells like gas again, you probably have a connection leak inside.
Lots of soap bubbles on every joint - watch for the bubbling. If that don't fix it, put plugs in the unit connectors and put a ten pound air test on it, and soap the joints again.
They sell test fluid, but it's not any better than bubbling dish soap, and costs more. Good luck.
Monkey44
Cape Cod Ma & Central Fla
Chevy 2500HD 4x4 DC-SB
2008 Lance 845
Back-country camping fanatic
1320Fastback
Vista, Ca
Posted: 12/19/19 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
I did a stupid last year. Thought i smelled propane when we stopped in Tucumcari after driving 600 miles. I could only smell it outside and at the rear of the trailer where there are no propane lines or anything so passed it off as maybe not propane or not our trailer. Stove and heater worked fine that night and didnt smell in the morning. Next day we head to Needles, Ca and our fuel stop was in Flagstaff where I smelled it again but this time at the front. I removed the tank cover and didnt see anything that looked loose or notice hissing or anything. We fueled up and headed to Needles and when we arrived I could smell it again. I knew there was no way we did not have a leak so took a big bottle of windex and laid under the trailer and found a fractured flare fitting right next to the leaf spring hangar. It was a copper flare where it joined a steel pipe heading to the to tongue. I figured somwhere before Tucumcari some road debris must of hit the pipe or the manufacture way over tightened it and it finally failed. Cost me at least 15 gallons of propane and had to drive home from Needles to San Diego with the genny running to keep the food cold/frozen.
Anyway if you smell propane you have a issue!
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
Old-Biscuit
Verde Valley
With reg and cyclinders completely removed the smell will go away ......some propane may leak from the open line from where reg connected to main lp piping.
Not sure why you removed the reg/cylinders but if leaving them out permanently then you should cap/plug the open line where reg was and another open line
mattyj
Posted: 12/20/19 02:45am Link  |  Quote  |  Print  |  Notify Moderator
. I Removed the regulator and the two tanks to try process of elimination because of the smell of propane, I will try airing everything out thanks
midnightsadie
ohio
Posted: 12/20/19 05:00am Link  |  Quote  |  Print  |  Notify Moderator
batteries burning up have a nasty smell.
ticki2
NH
Posted: 12/20/19 06:29am Link  |  Quote  |  Print  |  Notify Moderator
In addition to the above , I have noticed the odor is stronger as the bottles are nearing empty . It could also be the remaining gas and odorant in the lines after removing the regulator .
'68 Avion C-11
'02 GMC DRW D/A flatbed
Jayco-noslide
Galesburg,Il., USA
Posted: 12/20/19 09:03am Link  |  Quote  |  Print  |  Notify Moderator
I would get a new propane warning detector and if it shows propane I would rush to a professional and not mess around with it.
Jayco-noslide
 > Propane smell
