RV.Net Open Roads Forum: Can I put a sprocket made for a keyed shaft on a D bore?
 > Can I put a sprocket made for a keyed shaft on a D bore?
Naio
Snug as a bug in a rug
Posted: 12/19/19 11:02pm Link  |  Quote  |  Print  |  Notify Moderator
This is for my shave ice machine.
I overheated my motor and need to send it to a shop for rebuilding. I have available a possible temporary replacement motor. But my main motor has a keyed shaft, and the replacement has a D shaped shaft.
I talked to the people at the local sprocket shop where I am, and they said they thought I could use my keyed sprocket on the D shaped shaft. They suggested just tightening the set screw real well on the flat part of the D, and maybe even using a drill to make a dimple there.
The machine requires quite a bit of power and torque. When I used a 100 amp fuse I sometimes blew it. I now have a 200 amp circuit breaker which I have never blown.
I guess the worst case scenario is that the set screw would score the shaft of the temporary motor? Could anything else go wrong?
The drive sprocket is small and off the shelf. But the larger sprocket that the chain turns is new, aluminum, custom-made, and there's no way I'm ever going to get another one. Would I be endangering it in any way?
Here are some pictures, not of my equipment specifically, but of a sprocket that goes on a keyed shaft, and a one that goes on a D-shaped shaft, in case people are wondering what the heck I am talking about :-)
https://www.amazon.com/Yerf-Dog-Jackshaft-Sprocket-Tooth/dp/B01MSYOY2G
http://tncscooters.com/index.php?route=product/product&product_id=461
3/4 timing in a DIY van conversion. Backroads, mountains, boondocking, sometimes big cities for a change of pace.
pianotuna
Regina, SK, Canada
Posted: 12/20/19 05:18am Link  |  Quote  |  Print  |  Notify Moderator
Hi Naio,
I'd consider having a 3 d scan made of that sprocket so that if it ever fails, it could be 3 d printed.
As to the D shaft I can not offer advice.
Regards, Don
K Charles
Connecticut
Posted: 12/20/19 06:27am Link  |  Quote  |  Print  |  Notify Moderator
"I guess the worst case scenario is that the set screw would score the shaft of the temporary motor?" I think that is your answer. Drill a small hole for the setscrew, but not on the flat spot on the shaft.
* This post was edited 12/20/19 06:34am by K Charles *
Acampingwewillgo
Posted: 12/20/19 09:01am Link  |  Quote  |  Print  |  Notify Moderator
I'd check with "Spacely" to see if the proper sprocket is available. Say Hi to George,Jane, Judy, Elroy and Astro while waiting for your sprocket!!!
Sorry, I couldn't help myself when I read "sprocket".
Merry Christmas all!!! OK, Happy Holidays too.????
96 Vogue Prima Vista
The Kid's: Humphrie, the Mini Schnauzer and Georgie,wire haired dachshund, Senior Cavalier Rosie and Potter
Rainbow Bridge: Laddie,Scoutie,Katie,Cooper,Kodie,Rubie,Maggie, Cassie and Mollie, Elvis Love You!
Rally's and get togethers-Lots
RLS7201
Posted: 12/20/19 09:02am Link  |  Quote  |  Print  |  Notify Moderator
I cringe when I see only one set screw on a sprocket. Drill and tap for a second set screw and you'll be fine. The dimple is a great idea.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
ksg5000
Oregon
Posted: 12/20/19 09:37am Link  |  Quote  |  Print  |  Notify Moderator
I did something similar on my tractor - like you I figured that there wasn't much downside. Worked for a month or so which was long enough for the correct parts to arrive.
Kevin
schlep1967
Harrisburg, PA
Posted: 12/20/19 10:11am Link  |  Quote  |  Print  |  Notify Moderator
For some reason this bothers me more than anything you might do to make your sprocket work.
Did you happen to upgrade the wire when you "upgraded" the fuse?
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
pigman1
Delaware
Posted: 12/20/19 10:29am Link  |  Quote  |  Print  |  Notify Moderator
Are you trying to keep the D shaft on the temporary motor untouched? If NOT, I'd have a machine shop cut a keyway in that temporary motor shaft opposite the D flat. Then have them make a piece that would fill the open D area where the temporary shaft and the sprocket come together. Finally, a dimple on the insert piece that your set screw would mate into.
If you don't want to cut a keyway in the temporary motor shaft, a keyway could be cut into the piece you have made to fill the D area. Depending on how thick that piece is, the D piece may split at the keyway when high motor torque is supplied, but even if it cracked, it should stay in place if you make the fill piece to tight tolerances. If you use this solution I'd make it so tight I had to drive the key and the D shaped fill in piece on to the shaft. A snug interference fit.
My choice would be the first case. If you had to use the temp motor shaft for a matching sprocket, an open keyway opposite the D flat wouldn't cause any problems.
Pigman & Piglady
2013 Tiffin Allegro Bus 43' QGP
2011 Chevy Silverado 1500
SMI Air Force One toad brake
Street Atlas USA Plus
opnspaces
San Diego Ca
Posted: 12/20/19 10:30am Link  |  Quote  |  Print  |  Notify Moderator
Well it depends. Which sprocket has the set screw and key? Is it the easily replaceable one or the one that's hard to come by? Next question is how tightly does the sprocket fit on the shaft?
If the sprocket in question is the easily replaceable one. And the fit of the shaft is SNUG. I would go with just a set screw to the flat of the shaft.
If the sprocket in question is the easily replaceable one. And the fit of the shaft is loose but less than 4 thousandths of an inch loose(.004 is about the thickness of standard 20 lb printer paper). I would just set screw to the flat side of the shaft.
If the sprocket in question is the easily replaceable one. And the fit of the shaft is loose like MORE than 4 thousandths of an inch loose(.004 is about the thickness of standard 20 lb printer paper. Then I would drill a small dimple opposite the flat part of the shaft. If no drill, you could even just file the shaft a bit flat, but not anywhere near as flat as the other side, just a little flat. Then carefully and tightly wrap the shaft very smoothly with aluminum foil until it's about .004 loose, and scotch tape to hold it from unraveling until you can gently slide the sprocket on.
If the sprocket in question is NOT the easily replaceable one. I would only do the set screw to the flat of the shaft. And only of the fit is snug as in you can feel it dragging the sides of the hole when you press it on the shaft. Anything else and I would probably not mess with it until you get the motor repaired.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
fj12ryder
Platte City, MO
Posted: 12/20/19 10:45am Link  |  Quote  |  Print  |  Notify Moderator
Depending on long the "temporary" motor has to be in operation, a set screw into the flat on the shaft will work fine. Be sure to use a pointed setscrew, not a flat one, and use a drill bit to put a divot in the shaft where the setscrew will hit the shaft. Lastly use some blue Locktite on the setscrew, or use a double setscrew if there's enough room. Check frequently until replaced.
Howard and Peggy
"Don't Panic"
