RV.Net Open Roads Forum: Tech Issues: carburetor float failure
 > carburetor float failure
TOL
Posted: 12/20/19 10:41am Link  |  Quote  |  Print  |  Notify Moderator
I was having problems starting my 2 year old Onan 7000 Genorator Model 7HGJAB-900k this is well maintained by me. On my last 5000 mile trip I had notice that it had become hard to start at times or would stop while I was driving and hard to start at times, I was driving at high altitudes and hot weather, thought it might be getting a little warm checked it and made sure altitude adjustments on carburetor were at 5000 ft checked oil was able to start it after a little while this continued a few times during the trip. I am now at my snowbird destination and my generator won't start at all, so I went to looking deeper into the problem and found that the fuel float was full of fuel and allowed fuel to continue to flow freely into the caburater out the air cleaner and down along side the generator in my opinion THIS IS A SAFETY ISSUE !! raw fuel being poured out on a hot generator engine. That being said, if your having problems with flooding this should be something that needs to be checked. I have dealt with Onan before and as everyone I'm sure knows trying to talk to them can be like pulling teeth. This is not an uncommon problem and there are numerous posts on this issue and how to fix it with a 2 to 300 dollar new carburator. My quest here is to inform everyone of raw fuel on a hot eng when trying to start it, I will not be taking this to Onan, but to the agency's that can put a recall on this dilemma.
romore
Okanagan valley British Columbia
Posted: 12/20/19 11:04am Link  |  Quote  |  Print  |  Notify Moderator
I am a retired small engine tech and have seen this many times over the years. There is little anyone can do to prevent the problem short of buying a diesel which is fuel injected although the plastic floats are an improvement over brass.
ksg5000
Oregon
Posted: 12/20/19 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
I have had to replace floats in tractors/lawn mowers/chippers over the past 30+ years. Since all the floats are pretty much the same I am not surprised you occasionally get a bad one with Onan. If I had two year old Onan generator with bad float I would suggest talking to Onan rather than the govt.
Kevin
K Charles
Connecticut
Carburetor floats can be fixed, repaired or bought. You don't need to buy a carburetor to fix the problem. If it quits the fuel pump will stop. If it doesn't start in a few seconds stop at see why. Not much fuel is lost when it isn't running.
Tyler0215
Iowa
Posted: 12/20/19 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
Any small engine shop will sell a float and gasket. Install both and the problem is solved.
SidecarFlip
SE Michigan
Posted: 12/20/19 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
Buy and install yourself. easy peasy.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
Lynnmor
Red Lion
Posted: 12/21/19 01:45am Link  |  Quote  |  Print  |  Notify Moderator
It is almost impossible to buy many carburetor parts for Onan, just complete carburetors. If someone could provide a part number and a source it would be helpful to the OP.
Wherever I happen to park
Posted: 12/21/19 06:51am Link  |  Quote  |  Print  |  Notify Moderator
I too have seen this in a Car/Van (both actually) The cause was NOT float failure but needle valve failure.. and the cause of that turned out to be fuel pump failure.
The fuel pump diaphragm was flaking away and with a tiny piece of rubber got into the needle valve it could not close... Eventually the pump failed completly and then the problem .. went away.
I got real good at cleaning needle valves
Home is where I park it.
deltabravo
Spokane, WA
Posted: 12/21/19 07:33am Link  |  Quote  |  Print  |  Notify Moderator
I've seen it too.
Ehtanol in the fuel wrecks rubber parts in carbs that were designed prior to Ethanol. Ethanol in fuel has wrecked the carb on my DRZ400 three times.
Carb rebuild on power equipment / motorcycles is easy, providing you can buy the parts.
2015 Nash 17k (bought pre-owned 5/23/18)
westernrvparkowner
montana
Posted: 12/21/19 08:23am Link  |  Quote  |  Print  |  Notify Moderator
They are just looking for solutions at the wrong government level. Onans are sold around the world. Instead of seeking redress with the US government they should seek compensation at the World Court in the The Hague, Netherlands. That would be much easier than buying a new float or having a small engine shop repair the problem.
