RV.Net Open Roads Forum: Towing: Towing Limits
Search only in Towing
Open Roads Forum  >  Towing
 > Towing Limits
Bedlam
PNW
Posted: 12/20/19 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
Barney was complaining that the forum seemed little quiet, so I have an early Christmas present for him:
Chevy Silverado Driver Ticketed for Towing 53-Foot-Long Trailer
    A driver in Canada was ticketed for towing a 53-foot-long trailer with a light-duty pickup.
    The trailer was hitched to the truck via a pin system, which somehow worked.
https://www.msn.com/en-us/autos/news/che........r-towing-53-foot-long-trailer/ar-BBYcrmT
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE-VW TransBuggy 1200
gbopp
The Keystone State
Posted: 12/20/19 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
You're too late. This was posted by Fisher Bill today at 12:25 PM, in the fifth wheel forum.. [emoticon]
Bedlam
PNW
Posted: 12/20/19 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, I know little about fifth wheel towing but have done plenty of tag towing...
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/30015266.cfm
BenK
SF BayArea
Posted: 12/20/19 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
going over ratings won't have the wheels instantly fall off...but they will sooner than later...
-Ben Picture of my rig
Tyler0215
Iowa
Posted: 12/20/19 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
If the trailer was empty it could be well within the towing capacity of the truck.
Just shows the towing capacity can be misleading.
romore
Okanagan valley British Columbia
Posted: 12/20/19 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
I wonder how he activated the trailer brakes. If the wind caught the trailer it would be one wild ride!
Bedlam
PNW
Posted: 12/20/19 03:43pm Link  |  Quote  |  Print  |  Notify Moderator
This is more of an example of loading behind the axle and what leverage can accomplish. If you loaded the same weight of bricks forward or over the axle, I doubt you would have seen that bend.
Bedlam
PNW
Posted: 12/20/19 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
The driver did have some type or air system rigged to the trolley. I don't know if it was a static system to deactivate the trailer brakes or was electrically slaved to the truck braking.
blt2ski
Kirkland, Wa
Posted: 12/20/19 04:02pm Link  |  Quote  |  Print  |  Notify Moderator
Wondering what the actual citation was for per say. That trailer assuming empty! Does not wirgh more than 15,000 lbs. Obviously not over weight per Canadian equal of federal bridge law weights.
Safety is mentioned. A broad catch all that can get anyone off the road, towing or not......
The hitch at the truck does look a bit suspect.
Marty
Check RV.Net Blogs at: blog.rv.net
mich800
Pontiac, MI
Posted: 12/20/19 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
I don't think that is an air tank on the trolley. I read elsewhere they had something in the bed supplying the air. That looks like some type of fuel tank on the trolley and not hooked up if you look close.
 > Towing Limits
