RV.Net Open Roads Forum: Tech Issues: Norcold Refrigerator problem
 > Norcold Refrigerator problem
Spade Cooley
Mountain View, AR
Posted: 12/22/19 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
I'm in a park on power, 30amp in a travel trailer. I opened the door to the unit and the inside light goes out. I shut the door and the green power light flashes twice over and over. I looked at a guide and it says power or fan problem. I have no idea where the fan is or if I even have one. I never heard it run. I will call the repair service in the morning and for now I switched over to gas.
MDKMDK
Canada
Posted: 12/22/19 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
Year make model RV and fridge helps our resident refrigeration experts assist you.
Mike.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
rk911
Wheaton IL
Posted: 12/22/19 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
any other power issues or just the fridge? what happens if you switch the fridge to LP?
Rich
Ham Radio, Sport Pilot
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
Spade Cooley
Mountain View, AR
Posted: 12/22/19 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
In this park I have now and then tripped the breaker outside on the post. I went outside and l flipped the breaker on and off and the green light quit flashing. I still don't have a light inside the box. This park has had some issues with power. I also just noticed my propane sensor is not working right (flash red instead of green but no alarm going off) and its ten years old so I'm replacing it tomorrow.
Morcold N811 Sunset Trail 27RB 2009
rk911
Wheaton IL
Posted: 12/22/19 09:52pm Link  |  Quote  |  Print  |  Notify Moderator
is your air cond working?
- flip the post breaker off for 15-sec and then back on. same problem?
- have a volt/ohm meter? measure the voltage at the post.
- can you plug into a different post?
- unplug from post. start generator. same problem?
Flute Man
Payson, Arizona
Posted: 12/22/19 10:13pm Link  |  Quote  |  Print  |  Notify Moderator
It might be a problem with your 12 V. Might have bad batteries or maybe the converter is not working. Maybe you can find a local electrical person that has a meter that can help you.
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
2chiefsRus
USA Somewhere
Posted: 12/23/19 04:36am Link  |  Quote  |  Print  |  Notify Moderator
do your other 12 volt items work correctly?
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2018 Ford F-150 & 2017 Harley Trike
Fulltime 2007 to 2016, now halftimers
Before you give someone a piece of your mind, make sure you can get by with what will be left.
Our Blog
National Parks Visited
Spade Cooley
Mountain View, AR
Posted: 12/23/19 06:34am Link  |  Quote  |  Print  |  Notify Moderator
The refrigerator seems to be working properly now. I took my light out from inside the box, replaced it and even it now works. Last night I was watching my 12 volt ceiling lights and they do look dim. I'm starting to think my battery is weak or needs replacement. It should be time. Problem is I'm not sure what spes they call for on the battery. I suspect its just a deep cycle battery and I will go with the size I had. I read my book and they didn't say anything about type or size. 26 pull trailer with 30 amp system. 12 volt.
I look on rv sites and they have batteries that are upwards of $500. Yikes!
buddhawolf
New York
Posted: 12/23/19 11:23am Link  |  Quote  |  Print  |  Notify Moderator
If you feel your RV is not level, this is a good time to be sure your Dometic or Norcold refrigerator is not turned on. Your fridge can stay cold for hours without power. We can travel eight hours and the fridge will only drop a few degrees if we don't open the doors
Refrigerator review
mchero
Henniker, NH
Posted: 12/24/19 09:01am Link  |  Quote  |  Print  |  Notify Moderator
Whats the voltage on the house batteries?
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
