RV.Net Open Roads Forum: 2004 Windsor Monaco:MAIN SLIDEOUTS WONT OPERATE,Bedroom Does
 > 2004 Windsor Monaco:MAIN SLIDEOUTS WONT OPERATE,Bedroom Does
ichudov
Illinois
Posted: 12/22/19 10:14pm Link  |  Quote  |  Print  |  Notify Moderator
So I have this 2004 Monaco Windsor RV.
It has three slideouts: two opposed main room slideouts and the bedroom slideout. They always worked but I recall how every time we would struggle to remember what we had to do to enable the main room slideouts.
This time we seem to be out of luck: the bedroom slideout works, the two opposed slideouts do not. Specifically, there is NO motor noise of any kind and the switches operate absolutely nothing.
We did bring both driver and passenger seats all the way forward. We also closed all compartment doors. It does not help.
Any ideas what we may have forgotten or how to troubleshoot it.
Thanks
2003 Windsor Monaco 40PST Class A Motorhome
IB853347201
Eastern Ontario
Posted: 12/23/19 05:02am Link  |  Quote  |  Print  |  Notify Moderator
Parking Brake set?
Touring in our 2010 Suncruiser, beaches, site seeing, national parks, chillaxing..
Ivylog
Blairsville, GA and WPB, FL.
Posted: 12/23/19 07:53am Link  |  Quote  |  Print  |  Notify Moderator
The BR slide is mechanical and LR slides are hydraulic ...power pack is below the steps. Corrosion on the relay wire contacts is the usual problem and the motor has a normal starter solenoid...cleaning its connections is where I’d start since both do not work.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
[url=https://i.
RoyF
Fayetteville Arkansas
Posted: 12/23/19 08:18am Link  |  Quote  |  Print  |  Notify Moderator
In addition to coorosion, have you checked for a fuse in the hydralic-pump wiring? Has a wire to the pump become disconnected? (Bumpy roads can do that.)
ichudov
Illinois
Posted: 12/23/19 08:32am Link  |  Quote  |  Print  |  Notify Moderator
Honestly guys, I recall there is a rack and pinion and I do not think that it is hydraulic. I will tae a look. Worst case I can operate it manually with a wrench.
ichudov
Illinois
Posted: 12/23/19 10:24am Link  |  Quote  |  Print  |  Notify Moderator
An update. The slideouts have safety built in and only open when compartment doors are closed. Well, the plunger switches on doors were stuck due to age and not operational. I got them unstuck and the slideouts worked.
ArchHoagland
Clovis, CA, USA
Posted: 12/23/19 11:45am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the update.
Might want to hit those plunger switches with some silicon spray.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
ichudov
Illinois
Posted: 12/23/19 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
I have some motorcycle chain lube, hopefully it should work. Thanks
ArchHoagland
Clovis, CA, USA
Posted: 12/23/19 09:27pm Link  |  Quote  |  Print  |  Notify Moderator
I don't think I would use chain oil. I've used it on stuff and it's really thick.
ichudov
Illinois
Posted: 12/24/19 04:18am Link  |  Quote  |  Print  |  Notify Moderator
OK I will see if I can use something else... thanks
