RV.Net Open Roads Forum: Tech Issues: cruise control module
 > cruise control module
deepearth
Branson West, MO
Posted: 12/23/19 02:49pm Link  |  Quote  |  Print  |  Notify Moderator
I own a 1991 American Eagle fleetwood. The cruise control module has recently burned out. Is there anyone out there that can help me find a new module? The cruise control switch is early model GM. I'm assuming the module is to but I need information that can direct me to the correct module. Thanks
ScottG
Bothell Wa.
Posted: 12/23/19 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
Are you sure it isn't the actuator instead of the module? (Or are the they same assy on that year?)
At any rate, they like to develope a hole in the rubber diaphragm.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
opnspaces
San Diego Ca
Posted: 12/23/19 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
I don't have an answer but if all else fails you might check out dakotadigital. They make an aftermarket cruise control. I don't know if it would integrate with your switch, but might be worth taking a look at. Scroll down the page for the cruise controls.
Link
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Morro Bay, CA
Posted: 12/23/19 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
That’s really old...28+ years...for replacement parts.
Ava
Vancouver Island. BC Canada
Posted: 12/23/19 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
a faulty speed sensor can also be a common problem.
BarneyS
S.E. Lower Michigan
Posted: 12/24/19 08:20am Link  |  Quote  |  Print  |  Notify Moderator
Moved to Tech Issues forum from DIY.
wolfe10
Posted: 12/24/19 08:35am Link  |  Quote  |  Print  |  Notify Moderator
What BRAND and if you know, what model cruise is it?
Bendix?
What troubleshooting have you done to determine that it is the CC module that is bad?
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
mchero
Henniker, NH
Posted: 12/24/19 09:03am Link  |  Quote  |  Print  |  Notify Moderator
Improperly adjusted brake light switch can cause issues.
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
wolfe10
Posted: 12/24/19 09:37am Link  |  Quote  |  Print  |  Notify Moderator
Yup, a number of things can cause inoperative cruise controls.
That is why I asked about what troubleshooting lead to the diagnosis of bad module.
Gdetrailer
PA
Posted: 12/24/19 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
Why bother with fixing it?
Your foot can easily handle the task and have greater control of the speed which will result in better fuel mileage and much more stable speed since you can do something that cruise control cannot.. Anticipate the hills BEFORE you get there and lightly apply fuel BEFORE you start losing speed.
I tried cruise control once and noticed that when I came to any hill, it would wait until you lost a preset amount of speed then GUN the throttle to make up for the lost speed.. Might work OK with a lightly loaded car with bunches of excess HP and TQ, not so much with a heavy load like a RV that does not have excess HP and TQ for the load.
28+ yr old vehicle is pretty darned old, most parts have been taken off the books, off the shelf, off the market and often destroyed after a vehicle is 10 yrs old so you are 18+ yrs late to the party.
Troubleshooting can be a bear, sometimes design is changed midstream of the year or you might get real lucky have one that was built for one model year and nothing else fits or works. You really have to have a pretty good understanding of how your specific cruise works mechanically and electronically in order to troubleshoot without shotgunning parts at it.
