RV.Net Open Roads Forum: Tech Issues: water heater
 > water heater
Old-Biscuit
Verde Valley
Posted: 12/24/19 10:09am Link  |  Quote  |  Print  |  Notify Moderator
Before jumping to conclusions......do a little testing
Use voltmeter and check for 12VDC at the t-stats (under the cover above gas valve...right side is the 12VDC set for the propane)
DC comes from battery/dc dist fused source to the top t-stat (RED Wire) then goes to bottom t-stat via connection wire)
Got DC to top and out bottom then check for it at the circuit board.
No DC..then problem is back at On/Off switch OR from FUSED source.
Suburban rarely have issues with the circuit boards
ATWOOD DID Have for several years (2016 - 2018) due to change in vendor (Zhongding)
Little DC testing will pin point the issue quickly. THen you can buy/fix what is broken vs throwing parts at it
old guy
Oregon (pronounced Or e gun)
Posted: 12/24/19 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
suburbans are notorious for doing that. my tech came to my house for that reason and he wiggled a wire and the unit took right off. it was a connection thing
cpaulsen
Oregon
Posted: 12/24/19 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
For propane....it does not even attempt to light....no clicks!!! Checked all connections and still nothing. No red light comes for the switch ib the control panel. What a pain to get to the control board....take panel off inside the basement....wiggle your way in behind the furnace to get to the back of the water heater....geez.......what a design that is!!
cpaulsen
Old-Biscuit
Verde Valley
Posted: 12/25/19 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
That is NOT fault of Suburban.that is directly due to RV MFGs installation and not propviding access.
Thank them.
Have you done ANY testing on where you have DC and where you DON'T?
Could be No DC to Switch
Could be bad switch
Could be wire nut problem in DC Junction Box
Could be bad T-stats..or wiring on t-stats
Could be connection to circuit board
Simple voltmeter and follow the DC circuit
cpaulsen
Oregon
Posted: 12/25/19 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
All up and running
BFL13
Victoria, BC
Posted: 12/25/19 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
cpaulsen wrote:
All up and running
It would help us all if you explained what got it going. Thanks.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
AllegroD
Outdare
Posted: 12/25/19 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
BFL13 wrote:
cpaulsen wrote:
All up and running
x2 Sharing solutions is as important as sharing problems.
cpaulsen
Oregon
Posted: 12/26/19 05:50am Link  |  Quote  |  Print  |  Notify Moderator
What happened was....I had the electric portion on....and the water was to hot to make the propane fire up. Run the waterthru the taps till I used a lot of hot water which then got cool enough to let the propane fire up. Dumb me!!!
BFL13
Victoria, BC
Posted: 12/26/19 06:37am Link  |  Quote  |  Print  |  Notify Moderator
BTDT. Thanks for the follow-up.
Thunder Mountain
Lost in the Four Corners
Posted: 12/26/19 06:59am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for sharing the "solution". I'll file that one away in the data banks. Hopefully I can remember it if ever needed.
2016 Winnebago Journey 40R
2018 Rubicon
1982 FJ40 Toyota Land Cruiser
2020 Keystone Outback 327CG
2020 Dodge Ram 2500
Polaris RZR XP 1000
4 Cats
3 Dogs
1 Bottle of Jack Daniels
Two old hippies still trying to find ourselves!
 > water heater
