RV.Net Open Roads Forum: Tech Issues: water heater
 > water heater
cpaulsen
Oregon
Posted: 12/23/19 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
Sububran water will not ignite when on propane....electric portion works fine.....and yes...I do have propane
cpaulsen
MDKMDK
Canada
Posted: 12/23/19 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
Batteries enabled?
Usually need 12VDC power for w/h operation. For control board and DSI.
Other propane appliances working?
Mike.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
BFL13
Victoria, BC
Posted: 12/23/19 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
Did you try to reset the 12v Tstat?
Does the red light by the switch come on and just stay on, or does it not come on at all?
Does your digital voltmeter say the switch is getting 12v at all? If yes, is it getting to the circuit board? (Jumper the wires by-passing the switch to see if it is the switch failing to make the connection--if so get anew switch)
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
rk911
DuPage County
Posted: 12/23/19 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
will the stove light? if so let the burners burn for about 30-seconds and try again. you may have air in the line.
Rich
Ham Radio, Sport Pilot
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
Camping near Sandberg, CA
Posted: 12/23/19 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
rk911’s suggestion is spot on.
doxiemom11
Paris Michigan
Posted: 12/23/19 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
Ours is an Atwood, but exactly the same problem - wouldn't light on gas, worked fine on electric. It was the circuit board on ours.
RickLight
Washington
Posted: 12/23/19 10:18pm Link  |  Quote  |  Print  |  Notify Moderator
There was a bad run of controller boards. Get a dealer to check your board and install a replacement. (30 min job all told) A good shop will do all the warranty paperwork for you. (Thanks Xtreme RV Idaho)
Rick,
2019 Grand Design Reflection 150 273MK
2015 Ford F350 CC SB Lariat Powerstroke
PullRite Superglide
Wherever I happen to park
Posted: 12/24/19 04:36am Link  |  Quote  |  Print  |  Notify Moderator
I keep hearing this but frankly.. Think about it. Stove sips propane. Water heater guzzles it. (Same for Furnace) Water heater will try 3 times before it locks out.. You'd need like 100 feet of line full of air or more before the first two attempts would not purge.
But that said.. Won't hurt to light the stove as that confirms the propane system is indeed working.
To the O/P. You need to observe while someone else turns it on.
Does it light, go out re-light (three times no relight the 3rd time)
Does the thing make sparks (Snap SNap) but no ignition
Does it just sit there like it was turned off.
Once we know that we can get more specific.
Home is where I park it.
cpaulsen
Oregon
Posted: 12/24/19 05:34am Link  |  Quote  |  Print  |  Notify Moderator
All stove burners light....turn the gas water switch on......does not attempt to light.....red light does not come on. Have pretty much figured out the control board is bad. Did try the reset........no luck there also. Will order a new control board.2018 Montana HC...2 years old. Thinking the board is behind the convenience center.....will clean the basement storage out so I can remove the panel out so I can see if it is back there.
BFL13
Victoria, BC
Posted: 12/24/19 06:28am Link  |  Quote  |  Print  |  Notify Moderator
AFAIK, the switch is before the board, so first you should pull the switch with its red light, jumper the switch wires (not the light's) and see if that makes it all work.
Next is the connection of the wires to/from the switch and board at the board. I had an Atwood where that was the problem. Unplugged and plugged back to the board, which cleaned the contacts, and then the red light at the switch came on and everything worked.
* This post was edited 12/24/19 07:32am by BFL13 *
 > water heater
