RV.Net Open Roads Forum: Fifth-Wheels: Hard tonneau covers and 5er hitch
 > Hard tonneau covers and 5er hitch
irish31790
Reading, OH
Posted: 12/23/19 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
Hi folks. I have a new Ram 3500 short bed with a Curt A20 slider to tow our new fifth wheel. I am looking at the tri-fold style hard tonneau cover. My question is can the cover be left on the truck in the folded position while towing or do I need to completely remove the cover?
Mr. B
Reading, OH
2020 Cedar Creek Hathaway 34IK
2019 Ram 3500 Tradesman SRW Diesel
agesilaus
North Florida
Posted: 12/23/19 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
We had one, as a follow up to the soft roll up that came with the truck. The roll up was not a success with the hitch. The trifold was better but you still need to firmly tie down the cover in front of the hitch. The fiver generates a horizontal tornado in between the truck and truck bed and that tends to slam the bed cover around. So keep that in mind.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
Lantley
Ellicott City, Maryland
Posted: 12/23/19 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Bak Flip G2 that I am able to fold back and use with my hitch while towing. I have not experienced any wind issues.
2019 Duramax w/hips,2012 Open Range,Titan Disc Brake
H-head TPMS,BD3,RV safepower,17" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps
Correct Trax,Splendide
BB_TX
McKinney, Texas
Posted: 12/23/19 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
As long as the top of the hitch is below the top of the bed rails you should have no problem. My Pace Edwards hard roll type cover easily clears my hitch.
Durb
NW
Posted: 12/23/19 10:06pm Link  |  Quote  |  Print  |  Notify Moderator
I have an Extang tri-fold on an eight foot bed and have no problems towing when folded. There are clips that hold it in the open position. I would verify that your hitch pin placement is further rearward than one third of your bed length so that you pin box doesn't interfere with the cover. When my cover is folded, the stacked panels add about 2" of height over the bed rails. Not a problem towing but things can get a little close when backing tight up a hill. I still love the cover after five towing seasons with it.
jvharal
Tennessee
Posted: 12/24/19 03:51am Link  |  Quote  |  Print  |  Notify Moderator
Extang tri-fold no problems in two years
James, Virginia and Jackson (terrier mix)
2016 Ford F350 4x4 Dually
2015 Open Range 3X349 RLS
schlep1967
Harrisburg, PA
Posted: 12/24/19 04:42am Link  |  Quote  |  Print  |  Notify Moderator
I had one issue. If you are backing the 5er at an angle up a grade and the truck stays on more level ground, the nose of the trailer can get real close. Doesn't happen often but something to keep an eye on. Basically with mine, it takes up about 2 inches of space when folded. So you no longer have the 6 inches recommended above the bed rail.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
JKJavelin
Milwaukee, WI
Posted: 12/24/19 05:19am Link  |  Quote  |  Print  |  Notify Moderator
I have the Backflip Fibermax, 4 section. Fold it 3/4 of the way, lots of clearance with the standard pinbox. When I switched to a TrailAir pinbox I had to move the tonneau cover forward a little to clear the shock absorber.
JK
2018 Ram 3500 Laramie Cummins 6.7
2016 Open Range RF316RLS--Now with Titan Disc Brakes
Trailair pinbox
Morryde SRE-4000 w/ wetbolt kit
Demco Hijacker Autoslide 18k
2017- 21 Nights
2018- 75 Nights
2019- 138 Nights
2020- 22 Nights
RobWNY
Jamestown, NY
Posted: 12/24/19 06:06am Link  |  Quote  |  Print  |  Notify Moderator
I also have the Bakflip G2. I haven't had any problems. I do use the straps and buckle it.
If God didn't want us to eat cows, he wouldn't have made them out of Steak and Cheese.
Life is a lot like a baseball pitch. Sometimes you get a fast ball down the middle of the plate and sometimes you get a curve ball in the dirt.
MNRon
Tennessee
Posted: 12/24/19 07:57am Link  |  Quote  |  Print  |  Notify Moderator
Not a hard-too, but I’ve used a TonnoPro trifold for years on my 2013 Chevy SB. Works great, leave folded in front when traveling and flop it back over the hitch when 5ers disconnected.
Ron & Pat
2013 Silverado 3500 Duramax SRW
2019 VanLeigh Vilano 320 GK
