RV.Net Open Roads Forum: Technology Corner: Winegard mission
 > Winegard mission
enblethen
Moses Lake, WA
Posted: 12/26/19 11:15am Link  |  Quote  |  Print  |  Notify Moderator
Has the receiver ever worked?
Are you entering the "setup"? The get to satellite?
Have you tried using buttons on the receiver?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
tarnold
georgia
Posted: 12/26/19 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
Op. Yes worked from roof house antenna. When I get down to system info, how do you reset dish type as suggested by bill above. FRUSTRATING! Know it can be changed somehow?
enblethen
Moses Lake, WA
Posted: 12/26/19 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
Did you try running setup from the reciever buttons? Enter settings then setup
Does the dish make any noise? It should search for satelite without any receiver attached.
tarnold
georgia
Posted: 12/26/19 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
Yes. Just can’t get to the area to change the antenna type.
enblethen
Moses Lake, WA
Posted: 12/26/19 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
Have you tried pushing the reset button inside the door with the card? Try re-inserting the card.
GTO66
Posted: 12/26/19 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
You have to change the switch type from swm to multi-switch before you can select 18" round antenna at least I do with mine. I think if you hit exit/ menu that should bring up the page wear you can select repeat satellite setup. Then select multi-switch and then 18" round. hope this helps.
enblethen
Moses Lake, WA
Posted: 12/26/19 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
Another way to reset the receiver is to unplug the power cord from the receiver for fifteen to 20 seconds
Bill.Satellite
Full-timer
Posted: 12/27/19 05:28am Link  |  Quote  |  Print  |  Notify Moderator
Setup, repeat satellite setup (or similar) and go through the entire routine. You must get it off SWM and set to multi-switch. Try getting that far with the antenna powered off and when you get that set turn on the antenna and it might lock onto 101 if you can get it to multiswitch and 18" round before turning on the antenna, that would be better. Are you still using the D12 receiver?
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
tarnold
georgia
Posted: 12/27/19 11:40am Link  |  Quote  |  Print  |  Notify Moderator
Yes on the d12. When I can manage to get down to where you choose an antenna, I see about 17 different types. When I scroll, I see 18” round BUT when I try to highlight it it will jump right over it and go to the next one. It seems to be numbered 01, but can’t get the curser to sit on it?
enblethen
Moses Lake, WA
Posted: 12/27/19 11:44am Link  |  Quote  |  Print  |  Notify Moderator
change to Multi switch first
 > Winegard mission
