RV.Net Open Roads Forum: Travel Trailers: Tow Vehicle rating and comfort
 > Tow Vehicle rating and comfort
afidel
Cleveland
Posted: 12/27/19 06:47am Link  |  Quote  |  Print  |  Notify Moderator
Huntindog wrote:
All I could afford wrote:
It is possible to fill a F150 with 5 people, bikes, and food enough that you effectively have zero tow capacity because you have no capacity for the tongue weight
It is possible for me to do that with my 1 ton dually as well.
What, by loading the bed with pallets of water?
2017 KZ Sportsmen Classic 181BH
2015 GMC 1500 Sierra 4x4 5.3 3.42 long bed
E2 WDH
JIMNLIN
Oklahoma
Posted: 12/27/19 06:48am Link  |  Quote  |  Print  |  Notify Moderator
welcome to the forum jeraco.
The 3.5 EB engine and 3.31 gears and the 6 speed tranny will have no problems pulling that trailer.
The number you have to watch is that small 3800 RAWR Ford uses with the 6800 gvwr package. RAWR can be the lessor rating of a tire...wheel...rear spring pack....rear axle. With this trucks 6800 gvwr and 3800 rawr numbers its rear spring pack.
You have the truck so drop by a set of scales and weigh the trucks front and rear axles. This will tell you to the lb how much weigh will be in the bed and on the back of the truck. (example) Your trucks rear axle may weigh in the 2400 lb range which leaves around 1400 lb payload on the rear axle.
These numbers along with a weight distributing hitch mfg instructions can also help in setting up the WD hitch and dialing it in.
TomG2
Central Illinois
Posted: 12/27/19 07:59am Link  |  Quote  |  Print  |  Notify Moderator
Payload is king, since it takes the whole vehicle into consideration, not just individual components. One could put a huge rear axle under a Ranger and still be limited in towing capacity to the whole vehicle. My buddy put a F-350 rear axle under his F-150. It lived about six months after he loaded it to rear axle capacity.
Everyone has their personal preferences. When I tow 7,000 pound trailers, I want a 2500 series pickup. I like staying under 6,000 pounds with a half ton. I am more comfortable at fifty percent of capacity rather than ninety percent. That's what works for "me".
time2roll
Posted: 12/27/19 08:53am Link  |  Quote  |  Print  |  Notify Moderator
Yes an F150 with a 10,000+ tow capacity rating should be very comfortable towing a RV travel trailer with 6,800 GVWR.
675w Solar pictures back up
Boomerweps
Hills of PA
Posted: 12/27/19 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
Short answer: no problem.
IMHO, that size TT is in the "sweet spot" weight-wise for towing with your truck. As others have mentioned, just watch your tongue weight and truck loading not to exceed your CCC or RAWR.
2019 Wolf Pup 16 BHS Limited
2019 F150 SCrew STX SB 5.0 factory tow package
Huntindog
Phoenix AZ
Posted: 12/27/19 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
Take a look at my profile picture. If you still have any questions... Post them up.
Huntindog
100% boondocking
2010 Palomino Sabre 30 BHDS
84 gal. Grey. 84 gal. Black
2 bathrooms, no waiting
2020 Silverado High Country CC DA 4X4 Big Dually.
drsteve
Michigan
Posted: 12/28/19 08:15am Link  |  Quote  |  Print  |  Notify Moderator
I never noticed the quads in the bed until I enlarged the pic. Nice! I assume that's a hydraulic lift setup? How much weight does it add to the truck?
1991 Palomino Filly PUP
coolmom42
Middle Tennessee
Posted: 12/28/19 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
jeraco wrote:
Hi All! I'm having trouble deciphering the towing capacity of my truck.
Vehicle stats:
2016 Ford F-150 4x4 SuperCrew
3.5L V-6 EcoBoost
3.3 Axle ratio
GCWR 16100#
Conv. towing trailer cap 10,600#
Would my truck tow a UVW 5000# (6800# GVWR) trailer comfortably? I'm new to RVing and looking to purchase my first. I want to be comfortable towing i.e.having acceleration power and ability to get up inclines. If not, what kind of power should I be looking to get?
I look forward to your input! Thanks-j
You will be fine, unless you put a huge amount of heavy stuff in the bed of the truck. That Ecoboost is a towing beast.
2006 Toyota Sienna
Single empty-nester in Middle TN
Posted: 12/29/19 10:44am Link  |  Quote  |  Print  |  Notify Moderator
@drsteve. Side ramps onto a atv/sled deck. Drive up.
