RV.Net Open Roads Forum: Neat little fresh water in an ABS pipe idea
 > Neat little fresh water in an ABS pipe idea
pnichols
The Other California
Posted: 12/28/19 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
wopachop wrote:
Saw this down in sunny San Diego. There is a hose bib on the right side. My buddy said its common for the surfer guys to do this. Water gets warmed a bit in the black pipe.
If its 4", and roughly 60" long, it holds around 3.25 gallons.
If the steering wheel and coach door were on the other side (and the engine was supercharged), I'd rather have this VW instead ... it probably comes with a built-in water tank and water heater [emoticon] :
Phil, 2005 E450 Itasca Spirit 24V
pnichols
Posted: 12/28/19 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
richardcoxid
Idaho Falls, ID
Posted: 12/28/19 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
A gallon of water at standard temp and pressure is 231 cubic inches. Just figure the diameter in square inches and multiply by the length in inches and divide by 231 will give the volume in gallons
2017 GMC Denali 3500 4x4 Duramax
2019 Outdoor RV (ORV) Timber Ridge 24RKS
BFL13
Victoria, BC
Posted: 12/28/19 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
Phil, the over-the-cab part of the VW looks like it has a starboard list. Either DW or DH needs to go on a diet!
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
dodge guy
Bartlett IL
Posted: 12/28/19 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
Don’t forget guys. A 4” pipe is the outside diameter!
I would say around 3 gallons?
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
JaxDad
Greater Toronto Area
Posted: 12/29/19 07:26am Link  |  Quote  |  Print  |  Notify Moderator
I’m surprised none of the PC grumpy-pants in the crowd here have mentioned that the van is illegally parked.
[emoticon]
smthbros
WI
Posted: 12/29/19 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
I seldom venture south of the border, but up here in God's country, the nominal size of pipe refers to the inside diameter.
https://pvcfittingsdirect.com/pvc-pipe-sizes-chart/
Chum lee
Albuquerque, NM
Posted: 12/29/19 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
I used to work for a company that manufactured, designed with, and sold PVC/ABS SDR-XX plastic sewer pipe. You are correct. Nominal size generally refers to inside diameter. Not all plastic pipe is sized that way though.
Chum lee
PastorCharlie
NC
Posted: 12/29/19 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
A good garden sprayer painted black is a great shower in the rough and needs very little water to do a GI shower.
pnichols
Posted: 01/01/20 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
That's an outstanding Quick-And-Clean minimalist showering solution!!
Most garden sprayers are in the 3 to 5 gallon range. A 4 or 5 gallon model might be good for at least 2 hot showers.
(But to get around that I donated our camper van away years ago and went the small motorhome route ... and have been clean ever since. [emoticon] )
