RV.Net Open Roads Forum: Technology Corner: Contact List
 > Contact List
Kountryguy
Emery,SD
Posted: 12/27/19 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Kyocera Cadence phone that I have had less than 2 years. It does have a browser that is 4G LTE. I have never used it. I will plug it in to my PC and see what happens.
Kountryguy
Emery,SD
Posted: 12/27/19 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
Still no luck. Must be in the SIM card.
MrWizard
Traveling
Posted: 12/27/19 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have an micro SD memory card In the phone
If not get one and put it I there
A super cheap 4 gig card , is plenty large for just contacts
There should be an option or a downloadable app from the the vzw get it Now store, that will let you save the contract list on the memory card
It could have changed, but my phones all Verizon never did save contacts on the SIM card, which only used to identify the phone to the vzw cell system
Kyocera PC Drivers
Connect phone to pc via USB
Radiate The Happy
1997 F53 Bounder 36s
Kountryguy
Emery,SD
Posted: 12/27/19 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
Where would the micro memory card go in the phone? Would I need some kind of adapter?
Wherever I happen to park
Posted: 12/27/19 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
IF the phone is an Android Google may have a backup feature as well.
IOS I can't help you
Non-Smart.. Take notes cause I do not know
One thing I did in my non-smart days was save the contact list to teh SIM card, then transfer it to the new phone.. (Or you may be able to use a Memory card) Then transfer it back to the phone's memory then pop in the new sim.
But best if you have teh tech at the phone store do that kind of trick.
Home is where I park it.
2chiefsRus
USA Somewhere
Posted: 12/27/19 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
do you have a way to connect the phone to a laptop via a cable?
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2018 Ford F-150 & 2017 Harley Trike
Fulltime since October 2007
Before you give someone a piece of your mind, make sure you can get by with what will be left.
Our Blog
National Parks Visited
2chiefsRus
USA Somewhere
Posted: 12/27/19 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
if all else fails, read the manual
Kountryguy
Emery,SD
Posted: 12/27/19 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
I have read the manual and it is not at all detailed on how to do it. I do have a way to connect the phone to the laptop, which I have done and still not figured how to do it. Like I said, tech challenged.
MrWizard
Traveling
Posted: 12/27/19 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
Plugging in the cable is not enough
For the pc to correctly access phone operation and file system
You must install the windows pc drivers , on your pc
The phone must be turned on, then plug phone into usb
You will use windows explorer ie this pc
You treat the phone like it is an external USB memory stick/drive
And go thru file system folders until you find your contacts
Then save/copy that folder to your pc
Kountryguy
Emery,SD
Posted: 12/27/19 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks. Will try tomorrow. Leaving for the evening.
 > Contact List
