RV.Net Open Roads Forum: Tow Vehicles: Airing down tires on dually for beach
Search only in Tow Vehicles
 > Airing down tires on dually for beach
All I could afford
North jersey
Posted: 12/30/19 05:57am Link  |  Quote  |  Print  |  Notify Moderator
Contingency plan meaning a can of starting fluid and a long match?
1999 R-Vision Trail Light B17 hybrid
2006 Explorer Eddie Bauer
2002 Xterra rollin’ on 33’s
1993 Chevy Z24 Convertible
Lives in garage 71,000 miles
JRscooby
Indepmo
Posted: 12/30/19 09:14am Link  |  Quote  |  Print  |  Notify Moderator
I bought a truck that had braided steel line with check valves on each pair of duels. Wow! Easy to check/air. Put them on the truck I was working. Got to a bean field, MFIC says "Dump just this side of the gap in tree line. Somewhere in that field the dirt pulled/broke valve stem. PITA to get all the dirt out of tire. Bet sand would be about as bad.
All I could afford
North jersey
Posted: 12/30/19 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
Yup, very tough to bead up a tire coated with mud, pebbles, sand, etc even in a shop.
dennych1
Long Island New York
Posted: 01/02/20 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone I will start researching all suggestions before beach time rolls around. Got to love this site always get great info.
All I could afford
North jersey
Posted: 01/02/20 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
Looking forward to a full report after the trip! I love beach camping
deltabravo
Spokane, WA
Posted: 01/03/20 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
dennych1 wrote:
I have a 2019 f350 dually that I will be taking on the beach with truck camper.
1) what devices do you use to air down tires that is accurate.
Deflators and a tire gauge.
Stuck on the beach video
2018 Timberridge 24RLS (bought pre-owned 3/12/20)
BurbMan
Islip, Long Island
Posted: 01/08/20 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
I've had these Staun Deflators for 20 years now and they work great. I have them preset at 15 psi which is fine for most beaches around here. These are nice because you can screw them on, enjoy a cold beverage, and they automatically stop letting air out when they reach the pre-set pressure.
If you have regular LT E rated tires you won't have any issues breaking the bead as long as you stay above 10psi. Anything less than 10psi puts you at risk for breaking the bead.
If you are new to the beach it's a good idea to go out with someone your first couple trips. Also be aware of the state and county requirements depending on which permit/beaches you plan on using.
2015 Ram 3500 4x4 Laramie Crew Cab Long Box, Cummins diesel
Under renovations:
