RV.Net Open Roads Forum: Yellow window frame on door. Ugly. What to do?
 > Yellow window frame on door. Ugly. What to do?
BarneyS
S.E. Lower Michigan
Posted: 12/29/19 10:23am Link  |  Quote  |  Print  |  Notify Moderator
I painted all the yellowed plastic parts on our trailer about 13 years ago and they still look like new today. Used Krylon plastic paint as already mentioned by posters above.
Painted the two door window frames, entrance handle mounts, stove vent cover, outside elect covers, fridge vent on roof, and any other yellowed plastic parts.
I took the two window frames apart instead of masking. It was very easy and just took a few minutes to remove approximately 8 screws and the frame came right off.
I can't remember now whether I had to use a putty knife but probably not.
Barney
Not towing now.
Cummins12V98
on the road
Posted: 12/29/19 11:09am Link  |  Quote  |  Print  |  Notify Moderator
Simply order it without the USELESS window in the first place!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
larry barnhart
wenatchee. wa usa
Posted: 12/29/19 11:53am Link  |  Quote  |  Print  |  Notify Moderator
we like our door window and all of our windows on both sides and rear and slides because we like to look at the action.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Cummins12V98
on the road
Posted: 12/29/19 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
Window directly to left I can see out just fine. Window to right is bathroom.
Most door windows have frosted glass so why have it???
Chum lee
Albuquerque, NM
Posted: 12/29/19 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
Lynnmor wrote:
You can try wiping the yellow plastic with acetone on a paper towel. Wipe once and toss the paper towel, do not keep rubbing.
I agree with this for a quick clean only. When the technician replaced my Dometic 2652 refrigerator, in order to remove some of the adhesive tape residue from the new black plastic cabinet trim bezel, (the trim filler piece) he used an acetone soaked rag and wiped, . . . . . several times too many. That was the end of the factory textured finish. Now it's smooth as glass in a few locations, textured in others. Ooops!
Chum lee
larry barnhart
wenatchee. wa usa
Posted: 12/29/19 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
Ours is clear. Frosty would not be of any valve.
chevman
NJRVer
NJ
Posted: 12/30/19 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
chevman
Frosted lets light in, but keeps nosey eyes out.
keymastr
S.E. Washington
Posted: 12/30/19 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
You do know they make clear replacements with internal privacy blinds, right?
https://www.amazon.com/AP-Products-015-201512-Upgrading-Window/dp/B01MRRNQNP/ref=sr_1_4?crid=23NL92Y7LCDHO&keywords=rv+door+window+with+built-in+shade&qid=1577754281&sprefix=rv+door+window%2Caps%2C353&sr=8-4
blofgren
Surrey, B.C.
Posted: 01/01/20 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
ScottG wrote:
I painted the white frames on our last TT with Krylon Fusion. The results were beyond what I could have hoped for. Not only did they look like new, they also stayed that way for 5+ years until I traded it in. There were some small cracks in them that the Fusion filled as well.
Scott
This is exactly what I did and it worked fantastic.
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, RAM 20k sliding hitch, Retrax, Linex, and a bunch of options incl. cargo camera
Beaker
Brevard, NC
Posted: 01/02/20 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
Plain old bleach will turn it white but will yellow again.
I painted mine.
2008 Silverado 2500HD Duramax
2010 Cruiser 26RK
