RV.Net Open Roads Forum: Better/safer to have only one w/d bar? Or none?
Search only in Towing
Open Roads Forum  >  Towing
 > Better/safer to have only one w/d bar? Or none?
trailernovice
Mission TX
Posted: 12/29/19 06:51am Link  |  Quote  |  Print  |  Notify Moderator
One socket clip on my Reese round bar broke while on the road..it won't hold the bar now..
Getting a repair or replacement can't happen until after our return leg later this week
Our trip home about 325 miles
Left side bar and socket fine
Here's the question.. for our return trip, am I ok/better to run with a single w/d bar? In other words, is one better than none? Or does having a w/d bar on only one side create an unsafe imbalance situation or something, such that it's better/safer to run with no w/d at all?
Thx
Glenn and Toni
2019 Jayco JayFlight SLX8 264 BH
2019 Ram 1500 5.7 3.21 gears
Reese round bar w/d with sway control
pitch
NY
Posted: 12/29/19 07:53am Link  |  Quote  |  Print  |  Notify Moderator
Just opinion,but I would think that none at all would be the way to go.
I think that one would throw off your balance and unnaturally stress both the truck and trailer.
For only 325 miles I would go bareback, stay on secondary roads and reduce my speed.
Monterey, CA
Posted: 12/29/19 08:00am Link  |  Quote  |  Print  |  Notify Moderator
X2, pitch.
Boomerweps
Hills of PA
Posted: 12/29/19 08:09am Link  |  Quote  |  Print  |  Notify Moderator
Concur with pitch.
I have to get out of my drive and in the flat before installing the load bars. I failed to properly fasten one and lost it along the way from home to campsite, about 70 miles, over half interstate. Found it missing during set up. Didn't notice any difference while driving. Going home, I just used a basic ball mount vice hassling with the WDH heavy hitch head. There were noticeable winds on the interstate so I tried to limit my speeds 60-65MPH. On the way there, I was driving closer to 70 to stay with traffic, pushing 75 on the downhills.
I was concerned with a single bar putting a twisting force on the TT A-frame, WDH assembly, and htruck hitch/frame. My sway control is dependent on the load bars so I just drove a bit slower.
2019 Wolf Pup 16 BHS Limited
2019 F150 SCrew STX SB 5.0 factory tow package
wing_zealot
East of the Mississippi
Posted: 12/29/19 08:22am Link  |  Quote  |  Print  |  Notify Moderator
Really??
What if your drawbar breaks because you've exceeded its rating? Just speculating on what the other side of the coin looks like.
CarnationSailor
Carnation,WA
Posted: 12/29/19 08:44am Link  |  Quote  |  Print  |  Notify Moderator
Really??
Not sure, but I think the forces on a drawbar are about the same with or without a WDH. That is, I don't think the purpose of a WDH is to reduce the force on the drawbar.
2015 Crossroads Rushmore Springfield
2015 Chevy Silverado 2500HD Duramax
blt2ski
Kirkland, Wa
Posted: 12/29/19 09:18am Link  |  Quote  |  Print  |  Notify Moderator
Been there done that. Took them off.
Make sure trailer is reasonably level to nose down. May have to raise ball up a knitch. Otherwise. Head home.
Marty
Check RV.Net Blogs at: blog.rv.net
JRscooby
Indepmo
Posted: 12/29/19 09:23am Link  |  Quote  |  Print  |  Notify Moderator
Really??
Don't know about breaking drawbar. But "repair can't happen" worries me. If the WDH is needed for safe towing, fix it. If not, why have it? If it can't be repaired because your vacation time is more important than safe towing
BenK
SF BayArea
Posted: 12/29/19 09:25am Link  |  Quote  |  Print  |  Notify Moderator
Bungee cord, used them when still had the boat
Worked so well, kept them in case another emergency crossed our path
-Ben Picture of my rig
Ozlander
Rose Hill, Kansas
Posted: 12/29/19 09:31am Link  |  Quote  |  Print  |  Notify Moderator
I only use mine to keep the headlights down on the road.
Do a lot of towing without it.
Never any sway either way.
Ozlander
06 Yukon XL
2001 Trail-Lite 7253
