RV.Net Open Roads Forum: Class A Motorhomes: chassis battery
 > chassis battery
kemer
mn
Posted: 12/29/19 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
Is there a way to figure out what on a coach is pulling juice from the chassis battery and/or house battery? I know my front retracting night shades draw from chassis, but not sure what else. THANKS
Near Annett’s Mono Village, Bridgeport, CA
Posted: 12/29/19 03:08pm Link  |  Quote  |  Print  |  Notify Moderator
Unhook the house batteries and see what still works. Worth a try.
jy
south east mich.
Posted: 12/29/19 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
Unhook the battery and see what quits working.
2016 wildwood bunkhouse,2018 f150 5.0.Camping with the grandkids now.
enblethen
Moses Lake, WA
Posted: 12/29/19 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
If this on your Winnebago, go to their website and doewnload the wiring diagrams. You will need rig's information. VIN and serial number.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
time2roll
Posted: 12/29/19 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
Put your clamp-on DC ammeter on the battery cable and see what moves.
(any excuse to have a new tool [emoticon] )
675w Solar pictures back up
theoldwizard1
SE MI
Posted: 12/30/19 10:02am Link  |  Quote  |  Print  |  Notify Moderator
Nothing will "move" but if there is a draw, it should register. This is a case were "bigger is NOT better" ! You don't need a 600 amp-clamp meter. 100A is plenty. Around $50 on Amazon.
The next step is narrowing it down. Take you DMM and set it to the lowest voltage available. Open the fuse box under the hood, and place the test leads on each small metal contact on top of each fuse. If there is no draw, it should read zero.
If you find a suspect, remove the fuse and double check the total draw at the battery. Now you need a wiring diagram !
Remember, all the fancy electronics take up to 5 or 10 minutes to go to sleep, so wait for them !
Ava
Vancouver Island. BC Canada
Posted: 12/30/19 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
My older rig has two switches by the door. One turns the chassis battery on or off and the other turns the coach batteries on or off. I don’t know why newer units do not have the same simple switches. I have no parasitic draw from either when turned off.
ksg5000
Oregon
Posted: 12/30/19 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
Google parasitic battery drain - then disconnect the house battery and follow the Google instructions. In my rig the electric steps and alarms were connected to the chassis battery - after being stranded in the boonies with dead chassis battery I moved those over to the house battery.
Kevin
 > chassis battery
