RV.Net Open Roads Forum: Tech Issues: Changing Atwood water heater plug to brass
 > Changing Atwood water heater plug to brass
Page of 5
Wherever I happen to park
Posted: 12/30/19 05:36am Link  |  Quote  |  Print  |  Notify Moderator
The brass plug will work. for a while. but from chemistry class you should recall that dissimilar metals can react with each other badly and that is why the plug is NYLON. NOW there is an option. I think it's CPCV but please do not quote me on that. it's rated for the temps you find there. I've tried it with "Mixed" results (sometimes it seals sometimes it leaks) You use a nipple made of this stuff. then a 1/2 inch quarter turn valve then a piece of any pipe you like (Irrigation plastic pipe works very well or a brass plug
The nipple goes to the tank
The valve goes on the nipple
The plug goes in the valve's other end (Brass to brass) most of the time
When you drain the tank you first remove the plug, then screw in the plastic irrigation pipe (Cheapest **** you can get for this job) oh say 6-8 Inches long (this hauls the drain water past the side of the RV in case you wonder) then STAND CLEAR the drain and open valve.
First time I did this it worked very well
No joy since,
Home is where I park it.
Hondavalk
Toledo
Posted: 12/30/19 06:27am Link  |  Quote  |  Print  |  Notify Moderator
I have used a brass plug for years with no issue. I do wrap the threads with Teflon tape. Don't know if that makes a difference.
MDKMDK
Canada
Posted: 12/30/19 07:09am Link  |  Quote  |  Print  |  Notify Moderator
Just do what works for you. Teflon tape will help, reduce metal to metal contact if that's a concern. Brass is also a soft metal (use in brushes used for cleaning other metals). Installed caerfully, should be fine.
Mike.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
BFL13
Victoria, BC
Posted: 12/30/19 07:31am Link  |  Quote  |  Print  |  Notify Moderator
MrWizard wrote:
I am considering a brass plug, as my plastic plug and delicate Alu threads are leaking, even with Teflon tape on the plastic plug
Going to follow this thread
Maybe some pipe dope on a new plastic plug ?
I do drain once a year , and would prefer for it to be removable
Don't know if this is the same problem, but had an ageing leaky plastic plug that was also squishy in the socket turning it, no sharp corners anymore. New plastic plug fixed all that.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
DFord
Near St Louis, MO
Posted: 12/30/19 09:03am Link  |  Quote  |  Print  |  Notify Moderator
My Solution:
Works great for me. No tools required. I can still slip a plastic tube through the pipe to siphon out the water always left in the bottom of the water heater and often get some of the calcium flakes that end up on the bottom of the tank.
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
msmith1199
Reno, NV
Posted: 12/30/19 09:09am Link  |  Quote  |  Print  |  Notify Moderator
Wow, I kind of figured there would be lots of info on this topic. I went ahead and ordered the brass plug. Sounds like it will work for what I want it to do. Thanks for the info.
2004 National Tropi-Cal T-350, Class A, Triple slide, 330 HP Cat DP.
2019 Ford Ranger 4x4
2oldman
New Mexico
Posted: 12/30/19 09:44am Link  |  Quote  |  Print  |  Notify Moderator
Nice idea.
dougrainer
Carrolton, Texas
Posted: 12/30/19 10:12am Link  |  Quote  |  Print  |  Notify Moderator
Look at DE Fords post. THAT is the BEST way to do it. IF you leave a metal plug in the Atwood, it will "Gaul" after a few years even with Teflon tape. That means the Metal plug will be welded to the threads and almost impossible to remove. Atwood Tanks need frequent flushing for mineral build up, depending on your water quality. Having that fitting with a petcock REDUCES the opening for flushing out debris. Doug
ksg5000
Oregon
Posted: 12/30/19 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
DFord wrote:
My Solution:
Nice. What metal is the pipe?
Kevin
TurnThePage
North ID
Posted: 12/30/19 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
X2!! Share please!
A little surfing revealed this chart. Doesn't look very promising to me.
2015 Ram 1500
2004 Pioneer 18T6
Page of 5
