RV.Net Open Roads Forum: Tech Issues: Changing Atwood water heater plug to brass
 > Changing Atwood water heater plug to brass
Page of 5
Chum lee
Albuquerque, NM
Posted: 12/30/19 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
IMO, the biggest issue with using dissimilar metals is KNOWING when the plug is "tight" enough. Generally, the plug is tight enough just about 1/8 to 1/4 of a turn past the point where it stops leaking. No more. Using teflon tape for sealing is fine but it can facilitate tightening the plug too much. Remember, pipe threads are tapered and they exert a lot of force on the threads/hole/tank with very little effort and they are easily damaged, especially if you use a large wrench for the initial torque. If the used/reused plug leaks, just buy a new one (whatever material your choose) and don't keep tightening it.
Chum lee
Gdetrailer
PA
Posted: 12/30/19 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
MrWizard wrote:
I am considering a brass plug, as my plastic plug and delicate Alu threads are leaking, even with Teflon tape on the plastic plug
Going to follow this thread
Maybe some pipe dope on a new plastic plug ?
I do drain once a year , and would prefer for it to be removable
Buy a new Nylon plug when they start to seep/leak.
New Nylon plugs are cheap, new water heater, not so much.
Seeping or leaking means the Nylon PLUG is worn out and time to replace.
Teflon in this case just makes things leak worse, no need or reason to use it on the proper Nylon plugs. Teflon reduces the friction which allows one to continue tightening pipe.
As mentioned, pipe threads are tapered meaning the diameter is smaller on one end and increases on the male end (outside thread).
Female end (inside thread)the outside is larger and the further the pipe goes in the smaller it is.
Tapered pipe thread when done properly can actually seal without any need for Teflon or pipe dope.
I have a 110 yr old auto engine which uses spark plugs with tapered pipe threads, no Teflon or pipe dope and it still seals!
I do kind of like that brass pipe extension someone did. However with the cost of brass pipe, fittings and cap it couldn't be cheap.
Camco 2 pack of Nylon plugs $4.56 HERE
My water heater is going on 12 yrs with the original plug, I should buy a replacement soon since it is now worn enough that the plug is almost out of threads (remember, it IS tapered so as the plug wears down it will screw in further until you run out of threads).
I use a socket wrench with a short extension to tighten mine, start threading plug by hand then switch to socket wrench and only tighten enough to stop the seeping and no more.
bguy
The Rock
Posted: 12/30/19 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
Dissimilar? But the blow off is brass?
2011 Ram 1500 Quad Cab, 4x4, 3.55, HEMI
2009 TL-32BHS Trail-Lite by R-Vision
DFord
Near St Louis, MO
Posted: 12/30/19 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
ksg5000 wrote:
DFord wrote:
My Solution:
Works great for me. No tools required. I can still slip a plastic tube through the pipe to siphon out the water always left in the bottom of the water heater and often get some of the calcium flakes that end up on the bottom of the tank.
Nice. What metal is the pipe?
I used brass pipe. Everything is available from Ace Hdw, Lowes or HD. The 1/2" IPT adapter to male garden hose is a little hard to find but with a little searching you should be able to find one. The pipe is 1/2" brass. You'll need to measure the length you need for your water heater. The nipples are measured by total length. You lose about 3/8" to 1/2" on each end as you screw it into the fittings.
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
dougrainer
Carrolton, Texas
Posted: 12/30/19 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
DFORD pic looked plastic. You can get a Plastic type extension and do the same thing DFORD has done without using metal. Doug
TurnThePage
North ID
Posted: 12/30/19 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
Would that plastic be rated for the heat?
2015 Ram 1500
2004 Pioneer 18T6
larry cad
ohio
Posted: 12/31/19 05:52am Link  |  Quote  |  Print  |  Notify Moderator
PVC pipe is used frequently in hot water systems.
Our Travel Blog
Dusty R
Charlotte Michigan 48813
Posted: 12/31/19 06:42am Link  |  Quote  |  Print  |  Notify Moderator
NOT PVC but CPVC is rated for both hot and cold water.
Dusty
TurnThePage
North ID
Posted: 12/31/19 08:50am Link  |  Quote  |  Print  |  Notify Moderator
Did a little reading. CPVC is rated to 200F.
This sounds like a great winter project. Off to the hardware store.
opnspaces
San Diego Ca
Posted: 12/31/19 11:04am Link  |  Quote  |  Print  |  Notify Moderator
At the risk of Murphy or some other mythical rule maker biting me in the butt for admitting this. I'm am still using the original 15 year old nylon plug in my Atwood and I remove it often. The key is don't overtighten it.
Most people overtighten fasteners and in the case of the nylon plug it's easy to do.
Try it my way and I guarantee no leaks and you will stop cursing the nylon plug.
How to remove the plug:
  • Get the socket that fits the plug and a 6 inch extension.
  • Using your fingers slide the socket only up onto the plug.
  • Now hold the socket on the plug with one finger while you use your other hand to snap the extension into the socket.
  • Use a ratchet handle to loosen the plug.
  • Remove the ratchet handle and use your fingers on the 6 inch extension to unscrew the plug.
How to install the plug:
  • Using your fingers start the plug
  • Slide the socket only up onto the plug.
  • Tighten the plug with just your fingers on the extension until it's snug.
  • Put the ratchen handle in the extension.
  • Now tighten only about a 12th of a turn.(like from 12 -1 on a clock face).
That's it, it really doesn't have to be any tighter than that.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Page of 5
