RV.Net Open Roads Forum: Can installing weight distribution hitch be a DIY project?
Search only in Towing
Open Roads Forum  >  Towing
 > Can installing weight distribution hitch be a DIY project?
trailernovice
Mission TX
Posted: 12/31/19 01:53am Link  |  Quote  |  Print  |  Notify Moderator
As mentioned in another post, my w/d hitch and one of the tension bars is shot
I see an exact replacement online for a lot less than a dealer would charge
Is installing the hitch as a DIY project possible? I could pattern the settings from the unit I have now and then fine-tune it
Thx
Glenn and Toni
2019 Jayco JayFlight SLX8 264 BH
2019 Ram 1500 5.7 3.21 gears
Reese round bar w/d with sway control
bikendan
Camano Island, Wash.
Posted: 12/31/19 03:00am Link  |  Quote  |  Print  |  Notify Moderator
Certainly, it can be a DIY project. for example, for the 4pt. Equal-i-zer, there are tons of installation videos available.
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
Lynnmor
Red Lion
Posted: 12/31/19 03:04am Link  |  Quote  |  Print  |  Notify Moderator
Simple installation, here is a video.
dodge guy
Bartlett IL
Posted: 12/31/19 05:48am Link  |  Quote  |  Print  |  Notify Moderator
I'm positive you'll do a much better job than most dealers!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Mike134
Elgin
Posted: 12/31/19 06:13am Link  |  Quote  |  Print  |  Notify Moderator
I agree with him
Iraqvet05
Greenwood, MO
Posted: 12/31/19 06:32am Link  |  Quote  |  Print  |  Notify Moderator
It can be a DIY project but you may need some uncommon tools. In the case of the Equal-i-zer, a 1-7/8" thin wall socket and 320 lb torque wrench are recommended to install the ball. I didn't have a 1-7/8" socket that would fit in the trunion cavity so I had a trailer shop install my ball with an impact; they didn't have a torque wrench that large either.
2017 Ford F-250 6.2 gas
2018 Jayco 28BHBE
US Army veteran
JRscooby
Indepmo
Posted: 12/31/19 06:48am Link  |  Quote  |  Print  |  Notify Moderator
Like most things, when somebody says "Can I do it myself?" I can not answer, and wonder how anybody can. I can say "Yes, it's easy" but I know my tool and skill set. Who knows yours?
TurnThePage
North ID
Posted: 12/31/19 08:56am Link  |  Quote  |  Print  |  Notify Moderator
Definitely a do it yourself project. As mentioned, you may need special tools. Instead of purchasing those tools, I simply went to a shop and had them tighten an torque the big bolts. I offered them $20, they turned it down. Only took a second.
2015 Ram 1500
2004 Pioneer 18T6
goducks10
There
Posted: 12/31/19 09:53am Link  |  Quote  |  Print  |  Notify Moderator
If you don't know you probably should get some help.
opnspaces
San Diego Ca
Posted: 12/31/19 10:05am Link  |  Quote  |  Print  |  Notify Moderator
If you're comfortable with sockets and wrenches as well as a tape measure then I would say yes you can. One tip for when it comes time to tighten the hitch ball. Turn the hitch sideways in the receiver so the nut is pointing toward the drivers side of the tow vehicle. Now you can put your socket and bar on it and use your body weight to add some extra oomph.
Same thing goes for loosening the nut. Turn the receiver sideways so the nut points toward the passenger side and use your body weight to help break the nut free.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
