RV.Net Open Roads Forum: General RVing Issues: Kwikee Stairs failure rate
 > Kwikee Stairs failure rate
enblethen
Moses Lake, WA
Posted: 12/31/19 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
There is two grounds for the steps. one is for control and one for the motor circuit.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Wherever I happen to park
Posted: 01/01/20 04:43am Link  |  Quote  |  Print  |  Notify Moderator
I have yet to have a problem with controller or gears but it is my belief (I STRESS it is MY belief) that Kwikee uses 2nds for the motors and they have dead spots.. I managed to fight with it for 14 years then I popped in a new motor. a 1st, and it's working better.
I have a door switch issue but that has an override on it so it's no problem (I put in the override)
Home is where I park it.
jplante4
Cape Cod
Posted: 01/01/20 07:56am Link  |  Quote  |  Print  |  Notify Moderator
Mine are original to the 24 year old coach. Do you lube up the joints on a regular basis? I use motorcycle chain lube on the steps and the battery tray slides.
One more thought. My coach has a high voltage cutout on the step motor. It would kick in every once in a while. I solved this by leaving an interior light on and flipping on the battery switch pulled the volts down far enough to go under the trip point.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
Gjac
Milford, CT
Posted: 01/01/20 08:26am Link  |  Quote  |  Print  |  Notify Moderator
Mine are 24 years old also and were bent when I bought the MH in 2004. I straighten them out and used the MH for another couple of years and noticed they were always springy when I stepped on them. After checking I found a small dia screw that held the steps to the MH was sheared off, installed a larger dia screw and all was good again for a few more years until magnetic switch was loose in the lower door which I fixed. About 8 years ago the steps failed to retract. I went through all the tests on the Kwikee web site and determined it was the controller. I was told they no longer sold just the controller for a step that old and had to buy a whole new step assy. After some investigation I removed the control board from its case and saw one of the two relays was burned out. They control the in and out function of the steps. I think by not waiting for the steps to full extend when leaving the MH caused the relay to overheat from my weight while steps were still extending and burn the contacts. I replaced the relay for $3 and all was well again. I think for a 24 year old system they held up well.
MetalGator
Posted: 01/02/20 06:57am Link  |  Quote  |  Print  |  Notify Moderator
The stairs seem to be working for the time being. When they didn't work last week, I went back over to open the door to see if the light would come on underneath when I opened the door. Of course, the stairs were working at that time. The stairs are clean and were lubed the last time they were worked on.
2018 Miramar 35.3
2005 Dodge Ram Quad Cab 1500
3 fur kids (Monty, Lola and Pinto)
Rainbow bridge (Murphy)
enblethen
Moses Lake, WA
Posted: 01/02/20 08:56am Link  |  Quote  |  Print  |  Notify Moderator
I believe it is an electrical problem and not a mechanical one.
Need to check connections, grounds and power source when it is in failure mode.Stay clear of the step when testing!
RambleOnNW
Pacific Northwest
Posted: 01/03/20 12:46am Link  |  Quote  |  Print  |  Notify Moderator
We had our Kwikee electric steps not come out on a trip one time. And they didn’t come out for the whole trip. My eventual conclusion was I was not lubing one specific joint so the steps were jammed. Never have had an issue since.
I went through most of the troubleshooting procedure on my own but had to quit when it called for a special harness. Took it into Camping World then.
The tech there didn’t follow the procedure at all. He simply unbolted the motor and checked to see if the motor rotated back and forth when opening and closing the door, which it did.
I use the specified lube, Kwikee Kwik-Lube.
2006 Jayco 28', E450 6.8L V10, Bilstein HDs,
Roadmaster Anti-Sway Bars, Blue Ox TigerTrak
MetalGator
Posted: 01/03/20 06:48am Link  |  Quote  |  Print  |  Notify Moderator
This is my guess as well. I would think if the stairs were binding due to not being lubricated, I would at least hear the motor trying to work. I wish I would have thought to look underneath at the light when they weren't working.
memtb
Wyoming
Posted: 01/03/20 08:24am Link  |  Quote  |  Print  |  Notify Moderator
MetalGator wrote:
Are these Kwikee stairs prone to failure or am I just really unlucky? Our motorhome is 2 1/2 years old and I have had them repaired 4 times. The first time, the dealer was able to get them working without replacing any parts. The next 3 times I've had to replace the control module, the motor, and the gear. They have been working fine for the last 6 months or so but I opened the door on the motor home this weekend and they didn't come out. They stayed in the stored position. I opened and closed the door several times and they didn't work.
Next day I opened the door and the stairs worked fine. I am guessing they will fail again soon. The next time they fail, I think I am going to replace them with manual stairs.
Is this typical of the Kwikee stairs or am I just unlucky?
We keep our motorhome stored indoors in a garage and the stairs are lubricated. It's just really frustrating to keep having to repair these stairs.
Durability is likely dependent upon whether the steps are ....pre or post Lippert ownership of Kwikee! Much like everything else that Lippert has purchased, quality control has become virtually non-existent! memtb
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
