RV.Net Open Roads Forum: Tow Vehicles: 2004.5 Dodge 3500 towing capacity questions?
Search only in Tow Vehicles
 > 2004.5 Dodge 3500 towing capacity questions?
PNW_Steve
Pacific Northwet & cold
Posted: 12/31/19 11:20am Link  |  Quote  |  Print  |  Notify Moderator
Hello All,
I have a 2004.5 Dodge 3500 with CTD, Nv5600,4x3, 3.73 gears and 295/75R22.5 14-ply tires. Almost forgot: South Bend double disc clutch.
With the upgrades to the engine, clutch and tires I am a little bit lost as to how much I can safely tow.
I have a project coming up that will require me to pull a 15k pound trailer on a 30 mile round trip several times.
My understanding is that the first limiting factor, on these trucks is the rear tires. With the tire upgrade I have no clue as to how to figure out what my safe maximum tow weight is.
Any thoughts?
Thank you.
S.
2004.5 Dodge 3500 5.9 Cummins, NV5400, 5" turbo back stainless exhaust, Edger programmer & 22.5 Alcoa's
2002 Forest River 36 5th Wheel (staying home)
1992 Jayco 29 5th Wheel (Mexico veteran & headed back)
2002 "faux" Wanderlodge 40' My new toy....
romore
Okanagan valley British Columbia
Posted: 12/31/19 11:44am Link  |  Quote  |  Print  |  Notify Moderator
The legal towing capacity is set by the manufacturer and mods will not change that. They can make the vehicle more stable.
Old-Biscuit
Verde Valley
Posted: 12/31/19 11:51am Link  |  Quote  |  Print  |  Notify Moderator
15K is OVER your tow capacity regardless of tires/clutches etc
You still have truck AXLE weight ratings that will be maxed at 14K
I have 3500 SRW,.....14K 5th wheel puts me right at RAWR and under Rear tire max load rating
Posted: 12/31/19 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
Well that’s quite the combo! You use 1st gear taking off empty I presume with those 40” semi truck tires?
Obviously 15k is a bit over the OE rating, but you’re nowhere close to OE.
15k behind a very similar truck (our 07 with a canned tune and clutch) pulls just fine. I’ve towed that much or more a few times when my company half ton just wouldn’t cut it, lol.
That truck with a tuner and a stout clutch (or even an OE clutch) will pull 15k with relative ease on normal size tires.
The brodozer tires combined with the tall gears (for that tire size) will hurt that ability considerably.
With that clutch and rappin it out in each gear, I surmise it’s doable. But it will be much easier on you and the truck with some normal 32-34” tall tires.
It is short trips, but if you have to start out on or pull any significant grades, I’d 100% ditch the semi wheels for a cheap set of 8 lug OE type wheels and tires. (If you haven’t done a permanent 10 lug conversion). If relatively flat terrain, I’d try it but be ready to use 4 lo for maneuvering the trailer to stay off the clutch.
The “rest” of the truck will be fine if your brakes and driveshaft are in good shape and the trailer has good brakes.
Posted: 12/31/19 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
No, rear axle is good for 10klbs, tires are (obviously) way overkill. Might not have the springs for that tongue or pin weight though. He didn’t say.
Cheap/easy overload springs can be accomplished with wedges above the bottom leaf.
Going back to OE tires will put them into play load wise, but not a deal breaker if good 3500lb + rated tires in my experience.
Hauled a 2 ton TC many thousands of miles on heavy E rated tires. Short tips no problem or concern imo.
Durb
NW
Posted: 12/31/19 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
Those are some big tires for that truck, 6,000# per tire, same as my dually's tires combined. My guess is my 04.5 dually has the same 9,350# rear axle as your truck. With two people and around 400# in the bed, my rear axle weighs in at 3600#. The engine won't think twice about it but with a 40" tire rolling diameter you will be stressing your clutch and truck brakes. I'm assuming you are talking fifth wheel or gooseneck.
Poor advice here: I would make sure my trailer and truck brakes were top notch and tow the 30 miles. If my buddy's truck broke down, I wouldn't think twice about hooking up his 16k fifth wheel and towing it to a safe place.
ScottG
Bothell Wa.
Posted: 12/31/19 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
Your official towing capacity is roughly 14K#. That's for warranty and idiot proofing reasons.
A couple of thousand pounds more isn't going to be any issue at all.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
Bionic Man
Colorado
Posted: 12/31/19 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
I had an 03 with the HO engine and the NV5600. I towed 16,000 pounds (5er and boat tandem) for tens of thousands of miles. The only problem I had was that the rail pump died when it was 9 years old and 100,000 + miles. Never had any ill effects for towing that weight.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
Cummins12V98
on the road
Posted: 12/31/19 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
Bag it n carry on.
Why not everyone else does.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Morro Bay, CA
Posted: 12/31/19 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
“Short tips no problem or concern imo.“
Why are short trips no problem or concern? This isn’t a situation where you can pull off to let the engine or transmission cool off. It’s a weight issue. Failure can come at any time. Two miles from home or 2000.
