RV.Net Open Roads Forum: Class C Motorhomes: Genny ok in ABQ?
 > Genny ok in ABQ?
PartyOf Five
Wheaton, IL
Posted: 12/31/19 10:05pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks to support from many of you, our C's been parked for almost 2 months in Albuquerque, rather than in snowy Chicago. It sounded crazy at first, but there are so many in the area!
I winterized, cleaned, added Stabil, covered and locked it up. But I forgot to follow Onan's storage steps for the 4000 in the rush. We usually run it with load every month. So now what: hire a mobile tech? Take a quick trip? Wait till we go down for spring break? Find a local friend?
I'm inclined to play it safe, but thought I'd stick with tradition and ask the pros!
Da Moose:2001 31' E450. 30k in 3yrs.
PartyOf5: Driver's DW & 3 pre-teens -trying to connect, learn, appreciate creation & the Creator
May you find Peace in all that you endeavor
way2roll
Wilmington NC
Posted: 01/01/20 07:15am Link  |  Quote  |  Print  |  Notify Moderator
It will be fine until Spring. While it's good practice to exercise your genny monthly, it's not critical. Genny's can sit on the dealer lot for up to a year or more and still run fine. Some folks never exercise theirs at all.
midnightsadie
ohio
Posted: 01/01/20 09:04am Link  |  Quote  |  Print  |  Notify Moderator
x2 you should be fine.
Matt_Colie
Southeast Michigan
Posted: 01/01/20 10:00am Link  |  Quote  |  Print  |  Notify Moderator
The monthly exercise bit is from the people that sell parts. If it is gasoline powered, that is most of the problem. You need to drain the carburetor. In ABQ, the problem is going to be the old gas in it.
You can fly there irregularly and run it, or when you get back, try it then. If it does not fire right up, remove the carburetor and clean it. If no gaskets get torn, just put it back the way you found it.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
ron.dittmer
North-East Illinois
Posted: 01/01/20 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
For us, the gaps between generator run-times is typically 8 months, and there has been twice of 1 year and 8 months. Practicing this for over 12 years and all remains well. The rig is kept indoors which likely helps, but I do feel that if your rig is stored outdoors in a dry climate, it's not all that different from our situation except for potential for rodent and large critter damage.
I should also mention that I never use Stabel or other fuel additive for long term storage, nor any other type of fuel additive such as fuel system cleaners. I hear about Seafoam all the time but really know nothing about it. I store our rig with a full tank of regular gasoline.
2007 Phoenix Cruiser model 2350, with 2006 Jeep Liberty in-tow
Posted: 01/01/20 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
^Ron, you’re just lucky that that long of storage period with ethanol fuel hasn’t gummed up the carburetor on the genny once or twice at least.
EFI truck engine not so much. It can handle it more easily being a high pressure system and storing full, while it gives you a full tank of c rap gas to burn up, does help prevent moisture in the fuel.
Posted: 01/01/20 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
Party of 5, don’t worry about it.
Worst thing to happen is carb might gum up, but not too likely at only 6 months.
Not starting it for 6 months will not otherwise hurt anything else.
ron.dittmer
North-East Illinois
Posted: 01/01/20 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
I guess I am lucky.
What puts me at ease with my method, is all my lawn equipment and seasonally driven vehicles....no problems with any of them treated the same way for 31 years. Maybe the 10% ethonol helps rather than hurts. Who knows, I am no authority on this stuff. I only know what works with my gas powered things here at home.
My worst case situation was a 1986 Pontiac Fiero GT I parked in the back of our garage for 3 years, on blocks with a full tank of gas. The car ran slightly abnormal until I burned off the old fuel. A fresh tank of gas and the car was back to normal.
* This post was edited 01/01/20 07:53pm by ron.dittmer *
Posted: 01/02/20 01:52am Link  |  Quote  |  Print  |  Notify Moderator
^Yeah man, it's kinda luck of the draw, time, fuel quality combination.
With about 25 engines around the house and some that inevitably don't get used every year, it's easy to forget taking care of the fuel in one or more of them. And once in a while I have a carb varnish up and not start. Which is preferable to running lean from being partially plugged up and burning down an engine.
Chum lee
Albuquerque, NM
Posted: 01/02/20 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
When I bought my used 99 F53 Class A in 2011, the previous owner let the generator, a 4k gas Onan, sit for almost a year in Mesa, Arizona. The generator would start, but ran like ****, then it would die. With coaxing, it would eventually run, but, it would surge with changes in load. The now previous owner agreed to pay and have a mobile RV tech look at it. The tech said the carburetor was all gummed up. He replaced it with a new carb. +-$700 later and it was purring like new again. The generator then had +-300 hours on it. Now it's over 1,800. Just my experience.
Chum lee
 > Genny ok in ABQ?
