RV.Net Open Roads Forum: Tech Issues: Rivets.. suitable for the awning
 > Rivets.. suitable for the awning
groundhogy
PA
Posted: 01/01/20 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I need to replace some rivets that secure the awning parts to the side of the RV.
The existing rivets look different and stronger than standard pop rivets.
Does anyone know what these rivets are?
Thanks,
gH
Chris Bryant
Arden, North Carolina
Posted: 01/01/20 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
Search amazon for tri-fold rivets.
-- Chris Bryant
Second Chance
Wherever...
Posted: 01/01/20 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
The awning rail pulling away was an issue with some earlier Grand Design RVs. The rivets supplied by the manufacturer if you wanted to fix it yourself were called molly rivets. I repaired my awning rail with some in early 2016 and it's still holding well.
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
groundhogy
PA
Posted: 01/01/20 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
I have some of the tri fold rivets in the form of Olympic rivets and the head diameter is way too small. It would fall through the fixture hole.
Molly rivets. I have used these for household jobs. You pound them in and turn the supplied screw to expand the folds. Then remove the screw and use it to mount item.
groundhogy
PA
Neither looks like the original rivet.
alaska dennis
homer ak
Posted: 01/01/20 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
Are the rivets the same as what is used in car door window regulator. Go to a parts store and check the size.
theoldwizard1
SE MI
Posted: 01/01/20 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
Blind rivets come in many, MANY styles. The most important thing is to use the proper diameter for the hole and the proper length for the thickness of what is going to be mated. Backing "washers" or plates always help, but usually you can not reach in back of where they need to go.
Some manufactures make ones with oversized heads, but that does not solve the "pull through" problem. The tri-fold style look like a good solution and they are for sale on Amazon.
The "home-built" aircraft DIYers swear by CherryMax rivets. $$$ and not readily available.
Second Chance
Wherever...
Posted: 01/01/20 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
This does not at all describe the molly rivets I was provided. The ones sent to me by Grand Design mushroomed out on the back side but were installed with a standard rivet tool.
Rob
sayoung
Tx
Posted: 01/01/20 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
CherryMax blind rivet maybe ?
PNW_Steve
Pacific Northwet & cold
Posted: 01/01/20 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
Stainless closed end rivets of the appropriate diameter and grip range should work fine. I do recommend using rivets with a grip range that covers your material thickness plus a rivet backer. The rivet backer is basically a washer that will spread the load out
2004.5 Dodge 3500 5.9 Cummins, NV5400, 5" turbo back stainless exhaust, Edger programmer & 22.5 Alcoa's
2002 Forest River 36 5th Wheel (staying home)
1992 Jayco 29 5th Wheel (Mexico veteran & headed back)
2002 "faux" Wanderlodge 40' My new toy....
