RV.Net Open Roads Forum: Fifth-Wheels: Break away cable
 > Break away cable
Page of 5
mileshuff
Phoenix, AZ.
Posted: 01/01/20 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
Old-Biscuit wrote:
Been placing the loop in the cable over the arm of hitch for 20+ yrs.
Dang....didn't know it was 'incorrect'
BS!
Can be dangerous on some hitches. The cable can snag and pull the handle causing the hitch to release.
2014 Winnebago 26FWRKS 5th Wheel
2007.5 Dodge 2500 6.7L Diesel
2004 Dodge Durango Hemi 3.55 (Used to tow TT)
laknox
Arizona
Posted: 01/01/20 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Bird Freak wrote:
I have a clip on mine and attach it to the rear tie down in corner of bed.
So, do you also turn the e-brake base downward so that the cable will pull straight out or do you leave the base facing forward so that the cable would pull sideways out of the base, possibly snapping the pin before it pulls out?
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
Retired JSO
North Georgia Mountains
Posted: 01/01/20 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
I have a B&W Companion. The hitch arm locks in place with a snap pin. I put the pin through the loop and onto the locking arm.
Old-Biscuit
Verde Valley
Posted: 01/01/20 09:27pm Link  |  Quote  |  Print  |  Notify Moderator
BS!
Could be.....BUT NOT on mine
Handle has to be pulled straight out to release AFTER the pin is removed and locking latch is lifted up out of the way
Every 5th wheel hitch I have used the handle was pinned/latched in close position
MarkTwain
Northern, Ca. , USA
Posted: 01/01/20 10:33pm Link  |  Quote  |  Print  |  Notify Moderator
Me Again wrote:
The left rear puck lever/handle was what I did. You just have to be careful that it does not get tangled in something and pulled out.
Chris
Too avoid tangles, cut a 5" piece of clear plastic tube, slit the tube, insert the wire in the tube. This will keep the wire from tangling up on the hitch.
jaycocamprs
Ringgold Georgia
Posted: 01/02/20 04:43am Link  |  Quote  |  Print  |  Notify Moderator
MarkTwain wrote:
Chris
I also use the latching handle. Also use the coiled cable.
Pipeman
Windsor, Ontario,
Posted: 01/02/20 04:52am Link  |  Quote  |  Print  |  Notify Moderator
I attach my break away cable to the hitch via the hole where the hitch handle can be locked when closed. A small padlock fits into the hole and the cable hooks onto the hasp and then closed to the lock position. I've had 2 5th wheel trailers and this is how I've always attached the break away cable. The lock serves 2 purposes, keep the hitch handle from being pulled open by some idiot, who might pull the handle to the open position while I and my wife take a break at a rest area and keeps the breakaway cable in a safe place while traveling.
Pipeman
Ontario, Canada
35 year Fire Fighter(retired)
VE3PJF
padredw
East Texas
Posted: 01/02/20 06:31am Link  |  Quote  |  Print  |  Notify Moderator
I'm entirely with "Old Biscuit" and have been following his procedure for 23 years.
ford truck guy
Pennsylvania
Posted: 01/02/20 07:01am Link  |  Quote  |  Print  |  Notify Moderator
Lyle
I have a clip on mine as well and it's near the bottom of the base. I DID turn the base towards the ground so it is a straight pull if in fact that happens.
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 01/02/20 07:02am Link  |  Quote  |  Print  |  Notify Moderator
Given that some think the B&W head is design to separate under certain conditions, the cable should not be connected to anything on the head. I reality I believe that instructions say to connect it to the vehicle and not the hitch.
* This post was edited 01/02/20 08:43am by Me Again *
Page of 5
 > Break away cable
