RV.Net Open Roads Forum: Fifth-Wheels: Break away cable
 > Break away cable
Page of 5
hornet28
Muskegon
Posted: 01/12/20 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
bpounds wrote:
The coiled cables pretty much eliminate any chance of it snagging. Mine isn't hooked on the handle - it's hooked into the handle locking hasp with a carabiner. Serves to keep the handle locked as well as attach the brake cable.
The breakaway should be pointed towards the direction of pull. Not up as shown in this picture. If you loose the 5er the pin may stay in , break the loop off the pin or break the box. At best it will be delayed in activating the breaks
Cummins12V98
on the road
Posted: 01/12/20 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
The breakaway box is either attached with a pop river or a screw. It’s designed to rotate to where the cable will pull the pin. Only issue is the cable is attached to the hitch handle.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
hotpepperkid
Kingman AZ
Posted: 01/14/20 08:01am Link  |  Quote  |  Print  |  Notify Moderator
mileshuff wrote:
Old-Biscuit wrote:
Been placing the loop in the cable over the arm of hitch for 20+ yrs.
Dang....didn't know it was 'incorrect'
BS!
Can be dangerous on some hitches. The cable can snag and pull the handle causing the hitch to release.
Really! how does that happen when you put a pin in the hole
2019 Ford F-350 long bed SRW 4X4 6.4 PSD Grand Designs Reflection 295RL 5th wheel
Page of 5
 > Break away cable
