RV.Net Open Roads Forum: General RVing Issues: Suggest a wind generator
 > Suggest a wind generator
JoshuaH
Jefferson City, Mo
Posted: 01/01/20 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
We like to do off grid camping, haven't done any in a while since we had our son, but he is 4 now so we want to get back into it now that he is getting older. We did have a small pop up and I have a 100 watt solar panel, with that and a group 27 deep cycle battery we never had any problems camping for a week at a time, even running the furnace at night in colder weather (30-40s at night, using the furnace sparingly).
We now have a 17 Ft. travel trailer so I imagine our electrical demands will be higher. Was thinking of getting another panel, but obviously they only make electricity when the sun is up, and don't produce as much on cloudy days. Was wondering if a wind generator in combination with the 100 watt solar panel would be a good combination, and this could potentially generate some electricity at night if there is wind.
Looking for some suggestions, I don't need something that generates a lot, like I said we have never ran the battery down with one 100 watt panel before, we can get by pretty sparingly, camper has all LED lights etc.
Also is there a charging controller that you can hook both a solar panel and wind generator up to at the same time?
Thanks!
Morro Bay, CA
Posted: 01/01/20 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
WindyNation isn’t selling wind generators right now as I understand it, so I’m not sure it’s a viable way to recharge batteries in RVs. Yes, solar produces less on cloudy days. Buying an extra panel or two beyond what an energy survey indicates is necessary will solve that issue. Plus there is no daily setup and takedown with a roof mounted solar panel.
KD4UPL
Swoope, VA
Posted: 01/01/20 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
You don't want a wind turbine. In order for most of them to make their rated power they need a wind of about 28 mph. That's pretty stiff around here anyway. They also need to be mounted at least 30 feet above anything within 500 feet. Even if you're in wide open spaces putting up a 30 foot mast and guying it off would be a lot of work. Then there's the noise and vibration a spinning turbine generates.
Could you put a little one on a tiny mast and have it make a little bit of power in a light breeze? Maybe, but why? Just get another solar panel.
naturist
Lynchburg, VA
Posted: 01/01/20 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
Before you spring for a 92 AH group 27 battery, which I'm seeing for $300+ from Interstate, consider this 125 AH AGM for $289: https://www.amazon.com/Vmaxtanks-SLR125-Solar-Emergency-VMAX/dp/B004DR3IIC/ref=as_li_ss_tl?keywords=vmax+tanks&qid=1560295430&s=lawn-garden&sr=1-1&linkCode=sl1&tag=vehicledwelling-20&linkId=26a2244ebe8ea426f3f51fa2ff34c4b5&language=en_US
Being designed for solar applications, it is a true deep cycle battery, unlike most batteries billed as deep cycle, which are really just thinly disguised starting batteries. The clue here is when they list CCA among the specs. Cold cranking amps are not an important data point for deep cycle batteries.
bgum
South Louisiana
Posted: 01/01/20 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
Beware of false replies. Turbines are proven technology just like solar panels. Both have their +/-
Personal I like solar over turbines but they don't work in the shade.
time2roll
Posted: 01/01/20 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
I would fill your roof with solar before going into wind power. Aim for 300 to 500 watts.
I went with a small propane generator (Ryobi 700w) for charging the battery if conditions get extreme.
675w Solar pictures back up
free radical
Canada
Posted: 01/01/20 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
I wonder if one of these could be used on RV
https://www.windside.com/
Features include:
2-5 m/s cut-in wind speed
Up to 60 m/s max wind speed
50+ year lifespan
5-yr maintenance-free (optional)
Soundless Operation
No vibration
Graceful rotation
valhalla360
No paticular place.
Posted: 01/02/20 12:06am Link  |  Quote  |  Print  |  Notify Moderator
Wind generators are really dying out (not talking about the giant commercial units).
They are noisy, have limited wind ranges where they produce (too slow they produce next to nothing...too fast and you have to shut them down).
As someone else suggested, add solar until you run out of space...then you can consider other alternatives.
If you've set it up correctly, an occasional cloudy day won't be a big issue with a properly set up solar.
PS: had solar and wind on our boat but the wind generator needed a repair...10yr on when we sold the boat, we handed the box of wind generator parts to the new owner...never needed it.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
steveh27
Grosse Pointe Woods, MI
Posted: 01/02/20 05:00am Link  |  Quote  |  Print  |  Notify Moderator
I did some light research a few years ago & found these. Not sure if they are any good or still around. I never got one, I just use a 120 watt portable solar panel.
https://www.amazon.com/review/RM4KWVPU0LNMA?_encoding=UTF8&ASIN=B0076FXB8K&cdMSG=addedToThread&cdPage=&linkCode=&newContentID=MxKKDNM9OE5N7Y&newContentNum=1&nodeID=&ref_=cm_cr_pr_cmt&tag=#CustomerDiscussionsNRPB
https://www.amazon.com/Sunforce-44444-12-Volt-400-Watt-Generator/dp/B000C1Z2VE#productDetails
http://velacreations.com/howto/chispito/
dodge guy
Bartlett IL
Posted: 01/02/20 05:37am Link  |  Quote  |  Print  |  Notify Moderator
I could see a wind generator working in an open field, but in a forested campground with trees it probably won't spin fast enough even if there is high winds due to the trees blocking it.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
