RV.Net Open Roads Forum: Fifth-Wheels: "Lite" 5th wheels
 > "Lite" 5th wheels
salem
Central Valley, Ca
Posted: 01/02/20 10:30pm Link  |  Quote  |  Print  |  Notify Moderator
I seem to be seeing a lot of 5th wheels that are designated as "LITE." What exactly is the difference? Any reason to avoid the so called Lite trailers? The guy next to us has a Rockwood Lite 5th wheel that is 5 feet longer than mine but is about the same weight. I was just curious.
work2much
Jackson Ca
Posted: 01/02/20 10:49pm Link  |  Quote  |  Print  |  Notify Moderator
Some things I have noticed in some cases.
Smaller tanks, fridges, water heaters, frame sections, axles, wall sections, payload capacities, less durable interior finish materials. Often no generator option, single AC unit.
2017 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2018 Host Mammoth. 1080 Watts solar. 600 AH usable LFP battery. Magnum 2800 Watt inverter.
2018 Jeep Wrangler Unlimited toad.
wowens79
Georgia
Posted: 01/03/20 04:24am Link  |  Quote  |  Print  |  Notify Moderator
We’ve got a “lite”travel trailer, and to save weight they use really thin wood in lots of places. The “plywood” under the cushions of the dinette lasted 2 trips until my daughters knee went through it. The material reminded me of the balsa wood airplanes I played with. The floor is made of 2 pieces of a really thin plywood with foam between them. The floor feels springy when you walk on it.
Things can be made light and strong, but that usually is a more expensive material or construction method, neither of which I’ve seen on my trailer.
Unless you really need to save weight I would avoid the lite ones.
2002 Chevy Silverado 1500HD 6.0l 213k miles and climbing
2016 Heritage Glen 29BH
2003 Flagstaff 228D Pop Up
All I could afford
North jersey
Posted: 01/03/20 06:02am Link  |  Quote  |  Print  |  Notify Moderator
LITE DUTY stickers on the trailer would really clarify things
1999 R-Vision Trail Light B17 hybrid
2006 Explorer Eddie Bauer
2002 Xterra rollin’ on 33’s
1993 Chevy Z24 Convertible
Lives in garage 71,000 miles
RobWNY
Jamestown, NY
Posted: 01/03/20 06:40am Link  |  Quote  |  Print  |  Notify Moderator
"Lite" usually means Lite on Quality, Lite on Durability and often times means a lighter hit to your wallet but there are real problems and concerns if you go this route. I know. I bought a "Lite" 5th wheel new a year and a half ago and it's falling apart. So far I've had to stain and finish the dinette table, cut 1/4" off one leg of a dinette chair so it doesn't rock, tried to match a stain to hide the paper thin veneer on the MDF cabinets that has rubbed away, re-adjusted interior doors so they would close (wall flexing during towing is the culprit), Put gorilla tape over worn out areas where it rubs when opening/closing the trifold couch (this happened after using it as a bed maybe 20 times), Window treatments falling off etc. Then there's the lack of wall thickness and insulation that not only effects heating and cooling but there's no sound dampening either so you can hear everyone outside and everyone outside can hear you. These are just a few of the issues I've had in the one year of ownership of my "Lite" 5th wheel. Never again!
* This post was edited 01/03/20 04:08pm by RobWNY *
If God didn't want us to eat cows, he wouldn't have made them out of Steak and Cheese.
Life is a lot like a baseball pitch. Sometimes you get a fast ball down the middle of the plate and sometimes you get a curve ball in the dirt.
memtb
Wyoming
Posted: 01/03/20 08:17am Link  |  Quote  |  Print  |  Notify Moderator
Pretty much like comparing a “wood framed” WWI airplane to a WW II P-51 Mustang. They both will fly......! [emoticon] memtb
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
laknox
Arizona
Posted: 01/03/20 08:49am Link  |  Quote  |  Print  |  Notify Moderator
It's because of the proliferation of people wanting "trucks", i.e. half-ton, or lighter, trucks. Mfrs started making all these so-called 1500 or "half-ton" models which, in most cases, should be towed by a 3/4t, once they're loaded for camping.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
TXiceman
Full Time RVer
Posted: 01/03/20 09:04am Link  |  Quote  |  Print  |  Notify Moderator
LITE generally means CHEAP and lower quality on construction.
Ken
Amateur Radio Operator.
librty02
Western Pa
Posted: 01/03/20 09:29am Link  |  Quote  |  Print  |  Notify Moderator
All in all it is just a "marketing" scheme...
I have a "Ultra Light" Travel Trailer that I have over 40000 miles on in 7 years and close to 600 nights of use in also...
After the 1st fix of the shower p-trap not being connected correctly from factory
I have never had any issues at all
No cabinets loose ever
No feet through the floor
No issues at all
The only thing I do is keep it clean, Keep up with the maintenance on the roof seals seems etc and repack the wheel bearings yearly
I have seen on these forums over the years people paying 60 - 100g for thier so called top of the line rigs and have many many many costly issues with them.
Honestly its just the luck of the draw you either get a good one, an ok one, or a bad one...all depends on the technicians building the rigs mood that day...
2011 FORD F-150 FX4 CREW CAB ECO...
2018 Ford F-150 Max Tow Crew 6.5 3.5 Eco...
2013 Keystone Passport 2650BH, EQUAL-I-ZER 1K/10K
Jayco-noslide
Galesburg,Il., USA
Posted: 01/03/20 09:55am Link  |  Quote  |  Print  |  Notify Moderator
I think that term is mainly a selling gimmick. There is no standard as to what it really means. But if a trailer is truly "lite" I would wonder what is being left out.
Jayco-noslide
 > "Lite" 5th wheels
