RV.Net Open Roads Forum: Travel Trailers: Hey Y'all! Have a noob question!
Open Roads Forum  >  Travel Trailers  >  Small TT's
 > Hey Y'all! Have a noob question!
BoxerDogs
Katy Tx
Posted: 01/07/20 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
opnspaces wrote:
So I'm going to fly in opposition to some of the posts on here. I never, as in never, use any kind of holding tank treatment in my tanks. Been doing it this way for 14 years and don't have smell issues. I have also let my blank tank sit with stuff in it for the entire summer and it was no better or worse than dumping after a weekend of use. If there is more than a few gallons of water in your tank you will be fine. Where the problem comes in is when people don't use enough water when flushing and the poop just drops and piles under the toilet.
Since you're not going to be moving the trailer you won't have the benefit of water sloshing around and breaking up the pile and floating it away. So you're probably going to have to add enough water to the tanks after dumping that the poop can be float away.
Two other thoughts that popped into my mind when reading the replies above.
I think you misunderstood the cassette potty suggestion. Most of the popup tent trailers with bathrooms use a cassette potty. At the end of the weekend you pull the cassette out from under the toilet and carry it off to empty it into a toilet. The cassette automatically seals as you pull it out so aside from the actual minute you're pouring it into a toilet there is no mess or smell. Just pull the cassette at the end of the weekend and put it in the back of the truck and empty it at home. Just don't forget to bring the cassette back to the trailer when you come back the next weekend. If I had to make a choice between a 5 gallon cassette or a 20 gallon blue boy tote in the back of the truck. I would go with the cassette any day of the week.
Not to get into the legalities of the homemade septic idea, but you mentioned the nearest well is 4 miles away. You also mention filling the tank with lake water. You do realize the restrictions on septic placement and such are based on distances from water sources, not just wells. Hopefully the lake is uphill from or at least a good distance from all the home grown septic systems around it.
We've used a cassette toilet in the past. They tend to fill up pretty fast.
We're about thirty yards from the lake but as I said it's pretty much all sand which is a great filter.
There isnt that many people on this lease and very few have septic.
If I had to guess I'd say there's no more than ten camps on the 6k acres.
As far as the water in the lakes goes they're all crystal clear with a continuous flow of spring water and full of fish and gators.
I'd say there's far more deer scat in the water than anything else.
BoxerDogs
Katy Tx
Posted: 01/07/20 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
Another thing.
The place is crawling with wild hogs,coyotes,deer,and even a few black bears and cougars.
The hogs make their wallows right on the edge of the water and poop and pee right on the water's edge.
A buried system has nothing on the hogs.
rbpru
North Central Indiana
Posted: 01/07/20 10:16pm Link  |  Quote  |  Print  |  Notify Moderator
While we do not fill the tank before dumping, we do dump before leaving the park. No sense hauling all that extra weight and **** around.
When we dump the tank, I usually flush about a 5 gallon bucket of clear water down the stool.
When the water runs clear through the clear plastic elbow at the dump slinky hose, we are good to go.
You can develop any method that works for you. Most people do. If you screw up once, chances are you will not make the same mistake again.
Good luck
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
GrandpaKip
Flat Rock
Posted: 01/08/20 08:06am Link  |  Quote  |  Print  |  Notify Moderator
BoxerDogs wrote:
Another thing.
We had these type of systems all over one the lake areas in Florida. Nary a problem. The critters left more deposits than the humans, at least before a blue jillion people moved in.
I have the same type of thing at my house in the NC mountains, only on a larger scale. Big plastic tank connected to a drain field. Sure ain’t rocket science.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
BoxerDogs
Katy Tx
Posted: 01/08/20 10:32am Link  |  Quote  |  Print  |  Notify Moderator
GrandpaKip wrote:
BoxerDogs wrote:
Another thing.
Thats my take on it.
It's the same as a septic system on a smaller scale.
And the owners of the property dont have a problem with it.
BoxerDogs
Katy Tx
Posted: 01/08/20 10:36am Link  |  Quote  |  Print  |  Notify Moderator
Good luck
Once we get the redneck septic hooked up it'll be easy enough to empty after every stay.
Like you said,if it's not full enough to properly drain I'll dump five or ten gallons of lake water down the john and pump it out with the macerator.
smarty
new mexico
Posted: 01/08/20 11:12am Link  |  Quote  |  Print  |  Notify Moderator
I would be afraid of rat infestation if this rig is left for long in Texas. I hunt there and it is amazing how quickly rats infest anything and everything
BoxerDogs
Katy Tx
Posted: 01/08/20 02:27pm Link  |  Quote  |  Print  |  Notify Moderator
My friend and neighbor a couple of hundred yards away leave their fifth wheel out there and they've had zero problems with rodents.
We have plenty of bobcats and other predators to keep em in check.
If not there's always rat poison.
The biggest problem out there is wasp nests,coons and possums.
You definitely dont leave anything out you dont want to get eaten.
It cracks me up!!! When we come back from a fishing trip and fire up the electric fillet knife it's like a dinner bell to the smaller gators.
You wont be done with your second fish and there they are waiting for a handout.
