RV.Net Open Roads Forum: Fifth-Wheels: Keystone Montana for fulltiming??
 > Keystone Montana for fulltiming??
Cummins12V98
on the road
Posted: 01/06/20 09:34am Link  |  Quote  |  Print  |  Notify Moderator
" That is going to put a lot more stress on the tires, running gear and frame. For that kind of use the MORryde Independent Suspension System (IS) stands up much better than a leaf spring suspension."
I HIGHLY advise the MORryde IS suspension, anything else running FullTime will not hold up!!!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
cummins2014
Utah
Posted: 01/06/20 11:47am Link  |  Quote  |  Print  |  Notify Moderator
Thats a rather bold statement , had friends over yesterday, planning our Alaska trip starting in late May. They have been full timing now for 5 years with a 36' Big Country, conventional leaf spring suspension. Waiting to hear back from him on how many miles . They spent the entire summer ,and fall in the northeast this past year. They have traveled all over this country.
Although I don't full time , I have a 12 year old Montana fifth wheel , that has a lot of miles on it. Only thing I have done to the suspension is replace the shear springs on the MorRyde LRE suspension, which is a wear item. Plus added the wet bolt kit early on . Still the stock leaf springs.
Its going to get a few miles on it starting in mid Feb. to Arizona, and that state is pretty rough on suspension, pretty crappy roads , its been down there pretty much every year since new. Also it will get a pretty good workout on the Alaska trip , minimum of around 10K miles.
ependydad
Here and there
Posted: 01/06/20 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
I don't have a Keystone. But, last January I chatted with the online customer service about using mobile RV techs vs. taking the rig to a dealer. They said it was dealers or nothing for warranty service.
That's a non-starter for me.
[12:28:52 PM] System: To better serve you, please provide us the Vehicle Identification (VIN) Number.
[12:30:02 PM] System: Welcome to our live chat!
[12:30:02 PM] System: I am here to provide live assistance. How may I help you?
[12:30:02 PM] Me: Hi there. I'm considering a Keystone as an upcoming purchase. I wanted to find out what your warranty process is like if I need a mobile RV tech to come out or if I go to an RV service center?
[12:31:21 PM] Jeannene: We require all warranty concerns to be addressed at an authorized dealer after reporting any concerns to Keystone. In emergency situations, we can assist you if a mobile technician is needed
[12:31:50 PM] Me: So I can't start at a local RV service center that I've used before?
[12:32:25 PM] Jeannene: Onl;y if they are one of our authorized dealers
[12:33:05 PM] Me: No, they're independent and don't actually sell RVs. I find their scheduling and turnaround time to be much better than most dealers I've worked with (3-4 now). Hmm, ok.
[12:33:12 PM] Me: Thanks for the information.
[12:33:19 PM] Jeannene: you're welcome!
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
keh3491
Posted: 01/06/20 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
I am a dietitian and my husband is a nurse. We are traveling, doing contract that are usually 3 months at a time. Right now we stay in air b&b’s usually but it’s so hard packing up and moving that often and it gets very expensive. Our poor pets get so stressed when we keep uprooting them. So, this is why we are going to get the 5th wheel. We have borrowed the in-laws trailer before and got a little idea of what it’s like. Because we have been on the road for about 6 months now we have already down sized considerably and just rent a uhaul when we move. My husband drives an F250 so we know what we can pull. We are a little worried that the Montana may be a little heavy.
bpounds
Sophmore Brain...
Posted: 01/06/20 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
I think they are probably going to live in it full-time, not drive it around full-time.
Your husband is right about that. I won't say it can't be done, but it is more than an F250 is designed for. At a minimum, plan for some upgrades to your truck, if a new one isn't in the budget.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
keh3491
Posted: 01/06/20 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
So the F250 can pull 15,900 lbs.
MFL
Midwest
Posted: 01/06/20 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
All 250s are not the same. You need to state year, gas or diesel, tire rating, any suspension enhancement (springs/airbags,etc). A beefed up 250 would be at upper limit at that wt.
Jerry
bpounds
Sophmore Brain...
Posted: 01/06/20 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
The problem is how much it can carry. A fifth wheel places a heavy load in the bed, so truck payload is the critical factor, including tire rating. Montana's come in many sizes, but none of them are lightweights.
GDS-3950BH
DC
Posted: 01/06/20 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
Jerry
2940 pin per the tell tale website.
14K on the axles, 3K on the pin. What is that famous saying?
"I don't even know it's back there" [emoticon]
* This post was edited 01/06/20 02:43pm by GDS-3950BH *
MFL
Midwest
Posted: 01/06/20 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
With FW loaded to 16,900, you would likely need a DRW 350, as you would likely be over RAWR/tire rating. The 2940 pin wt per site, would be an unloaded pin wt. Once loaded for full time living, that pin wt will likely be 4K+. Seems you are correct to think what ever 250 you have will not work for that FW.
Jerry
