RV.Net Open Roads Forum: Tech Issues: Water pressure problem
 > Water pressure problem
Nicodemus
Hoodsport WA
Posted: 01/04/20 11:59pm Link  |  Quote  |  Print  |  Notify Moderator
We have a Prime Time Spartan. The water at the kitchen sink is a dribble, and the water flow at the bathroom sink is only slightly better. However, the shower has great pressure. I can't figure out why this is so or how to correct it. We use a regulator because the manager said that the pressure is high. Any ideas?
craig7h
Branson MO area
Posted: 01/05/20 04:27am Link  |  Quote  |  Print  |  Notify Moderator
Have you checked and cleaned the aerator screen at the end of the faucet? You might also want to check to see if you have any type of screens on the water connection to your coach.
Itasca Meridian SE 36g
Road Master Tow Dolly
midnightsadie
ohio
Posted: 01/05/20 05:03am Link  |  Quote  |  Print  |  Notify Moderator
x2 take the end of the faucet off and clean or throw away.
Bobbo
Wherever I park
Posted: 01/05/20 07:06am Link  |  Quote  |  Print  |  Notify Moderator
Agreed. I have to clean my faucet screens every couple of years. I try to remember to do it every year when I de-winterize just to prevent the problem in the first place.
Bobbo and Lin
All I could afford
North jersey
Posted: 01/05/20 07:47am Link  |  Quote  |  Print  |  Notify Moderator
Agree, if only at one faucet, then clean your screen
1999 R-Vision Trail Light B17 hybrid
2006 Explorer Eddie Bauer
2002 Xterra rollin’ on 33’s
1993 Chevy Z24 Convertible
Lives in garage 71,000 miles
ksg5000
Oregon
Posted: 01/05/20 08:11am Link  |  Quote  |  Print  |  Notify Moderator
Is water pressure low on both hot and cold?
Kevin
MDKMDK
Canada
Posted: 01/05/20 08:52am Link  |  Quote  |  Print  |  Notify Moderator
Are there water filters on the lines feeding these 2 sinks? Our galley sink has one, but I don't think the bath one does. Aerators (clean/replace) are a good place to start.
Mike.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
rrupert
NW PA
Posted: 01/05/20 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
Check the strainer on the water pump if you are using water from the fresh water tank.
Rich and Joyce
2018 Jayco Jay Flight 21QB
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
old guy
Oregon (pronounced Or e gun)
Posted: 01/05/20 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
I wish I knew the answer or how to correct this problem. I have the same problem and yes I have cleaned the screens and have replaced the screens and cleaned out the washers in the valves. nothing has worked. the answers you got above are just the tip of the iceberg, just the start of going mad trying to figure this out. I'm beginning to think it is an engineering design
Nicodemus
Hoodsport WA
Posted: 01/05/20 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the input everyone. I shall attempt to remove the kitchen faucet top and see if the screen is the problem. It affects both the hot and cold water. Not using our tank but I should check to see if it does this when on the pump. Should I disconnect from city water first? We didn't have this problem in the prior park, so I don't think it's a design defect. Unfortunately the bathroom sink is not the kind you can unscrew so I don't know how that will be fixed.
