RV.Net Open Roads Forum: Tech Issues: Water heater INOP on electric
 > Water heater INOP on electric
drillagent
Mostly Wyoming
Posted: 01/05/20 08:47am Link  |  Quote  |  Print  |  Notify Moderator
Noticed the other day that my Suburban 12 gal water heater was not heating on electric. Gas works fine. Replaced the element and it worked for about 10 min then quit. Any suggestions? Really don't want to call a repair guy if I don't have too.
TV: 2012 F250 CC SB SRW 6.7L Diesel w/air lift suspension
CHU: 2012 Keystone Montana 3750FL
Hitch: B&W Turnover Ball w/ Companion 3500
Family: Me, HH6, a Boston Terrier, a Shiba Inu
Sam Spade
North Central Florida
Posted: 01/05/20 08:55am Link  |  Quote  |  Print  |  Notify Moderator
You need a multi-meter if you are going to do your own electrical work.
Lacking that, "call a repair guy".
Or pretend that it doesn't HAVE an electric option.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
CA Traveler
The Western States
Posted: 01/05/20 09:23am Link  |  Quote  |  Print  |  Notify Moderator
Turn off the power and check all connections. A $10 voltmeter (used with safety kowledge) can establish voltage at the element wires. And a clampon ammeter can determine amps. It could also be other components that failed.
2014 Grand Cherokee Overland
Bob
All I could afford
North jersey
Posted: 01/05/20 11:14am Link  |  Quote  |  Print  |  Notify Moderator
Interesting that it would work for 10 minutes on the new element and then stop again. How did the old element that you removed look? I would start by checking for continuity with a meter on the old element to see if it’s good or bad
1999 R-Vision Trail Light B17 hybrid
2006 Explorer Eddie Bauer
2002 Xterra rollin’ on 33’s
1993 Chevy Z24 Convertible
Lives in garage 71,000 miles
Old-Biscuit
Verde Valley
Posted: 01/05/20 11:45am Link  |  Quote  |  Print  |  Notify Moderator
T-stats.......
Under the cover above gas valve----Left Side 120VAC black wires
High temp is top one.manual reset (trips at 180*F)
Normal temp is bottom one (Opens at 130*F)
12th Man Fan
Flower Mound , Texas
Posted: 01/05/20 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
Check wall plug also it could be loosing connection there. I had one that would do that but it should not do it setting still.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
Monterey, CA
Posted: 01/05/20 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
Like 12th Man, I’d check the wall plug first.
