RV.Net Open Roads Forum: Tech Issues: Fresh Tank Filling on City Water
 > Fresh Tank Filling on City Water
Second Chance
Wherever...
Posted: 01/05/20 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
ScottG wrote:
avarusbrightfyre wrote:
Ok, so I was poking around in my water intake area trying to figure out getting the valve out, and now I'm noticing that my water pump is kicking on every few seconds for like a 1 second burst, which I assume means it's losing pressure somewhere?
Yes, it's leaking backwards into the tank. Do as I posted earlier or I guess just learn to live with it.
Don't think so. When there's an O-ring problem, the lines don't get up to pressure to shut the pump off - it just keeps pumping water back into the tank.
Rob
U.S. Army retired
2016 Grand Design Reflection 337RLS
MOR/ryde independent suspension, disc brakes, LR G tires
2020 Solitude 310GK-R on order (with MORryde IS)
PullRite OE 18K, Demco Glide Ride pin box
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
ScottG
Bothell Wa.
Posted: 01/05/20 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
Rob
Not sure what O-rings your talking about but the issue the OP is experiencing is related to the diaphram area. I have fixed three different pumps that failed in this way just by cleaning.
OP, Since cleaning it didn't help and one of the screws is stripped and keeping that diaphragm from sealing internally, the pump needs to be replaced. Or you can install a manual valve before the pump but you risk the pump developing an external leak in the future.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
LadyRVer
Posted: 01/05/20 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
My last travel trailer did that and it was the check valve in the pump. The dealer ended up installing a turn-off valve so the city water would not run into the fresh water tank. Fine, except when you wanted to fill the fresh water tank, you had to turn that newly installed valve on. But, it did fix the problem.. for the time being.
Old-Biscuit
Verde Valley
Posted: 01/05/20 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
FILL Valve....leaking thru
Second Chance
Wherever...
Posted: 01/05/20 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
This... again...
Rob
avarusbrightfyre
San Diego
Posted: 01/05/20 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
So as a temporary fix, I decided to adjust the plumbing to bypass the tank select valve completely so that way whatever is causing the problem is also bypassed and the city water won't leak into the tank. Turned out to be way harder than I thought. The factory setup had permanently affixed connections to most of the fittings in that area, which makes absolutely no sense to me, but whatever. I'm going to order parts to make all the connections in that area screw on connectors so I can easily pull out parts for cleaning, o-ring replacement, and whatever else might be needed. If the pump still has issues after that, which I'm sure it will because of that one screw, I'll replace it as well and see if that rectifies the issue. At the end of the day, though, I just don't want water leaking out of my trailer.
2019 34' Minnie Plus Travel Trailer
San Diego, CA
bucky
Raleigh metro
Posted: 01/06/20 05:10am Link  |  Quote  |  Print  |  Notify Moderator
Lwiddis wrote:
Bucky, and if upon arrival no water is available? I never leave home or a campground without a full fresh water tank if available. If a TV and/or TT can’t handle the weight, someone bought the wrong TV and/or TT. Lots of beautiful DRY campgrounds in the West.
Good point. I usually only travel with enough for potty stops if needed.
* This post was edited 01/06/20 05:18am by bucky *
2005 Cummins 2500 2WD LB quad cab pulling a 2014 Blue Ridge 3025RL
GenoB
Parker Strip, AZ
Posted: 01/07/20 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
Just a comment regarding fresh water tanks :
I've been RVing since the early 90's with several different RV's types. In general here is how I use the internal water tanks when traveling (not when parked on city water)
a) I never use the fresh water tank for cooking or drinking or brushing teeth
b) I DO use the fresh water tank for washing dishes, showers, general wash basin uses, toilet, etc
c) I keep the tank about 1/4 or less filled when stationary in RV park, more if needed when traveling.
d) I put about a cap full of bleach when adding water to the tank to keep water from going rancid
e) I do all my cooking and drinking with bottled water
Just me personally, has worked well for me over the years. I don't like leaving a tank dry / empty, things dry up and crack, etc. Never had any problems with the tanks using these methods...
wolfe10
Posted: 01/08/20 07:38am Link  |  Quote  |  Print  |  Notify Moderator
And we do the opposite. Use only tank water-- refilling and dumping gray and black when out of potable water.
This way tank water is always fresh. And, this gives us the option of not filling with CG water if it is poor quality.
Yes, sanitize tank at the beginning of each trip/if water over 2 weeks old in summer or 3 weeks old in winter.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Bill.Satellite
Full-timer
Posted: 01/08/20 08:29am Link  |  Quote  |  Print  |  Notify Moderator
I do the same. I always supply the coach from the fresh water tank using the water pumps. I fill the tank when it's empty and dump both holding tanks at the same time. I keep both of those closed until it's time to dump to ensure enough water volume for a good clean dump. The fresh water tank is always clean and safe to drink due to the fresh supply of chlorine in the city water supply.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
