RV.Net Open Roads Forum: Suburban SW6 lights but drops out after 30+ seconds
 > Suburban SW6 lights but drops out after 30+ seconds
BFL13
Victoria, BC
Posted: 01/07/20 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the follow-up! Really good work finding that.
OK, now my other question-- what's with this? "h) DC power is always 12.5vdc"
If you are on shore power, 13.6v converter, 12.5 is a big drop to the WH IMO. If on battery, 12.5 is about 75% SOC and is not constant--so not "always".
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
GenoB
Parker Strip, AZ
Posted: 01/07/20 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
Ummmmm... well food for thought isn't it ! I agree but my little Toy Hauler has always had about 12.5 vdc battery reading on my solar power regulator and when on shore power ? Same reading on my digital meter when checking wiring, etc.. Might be because of my old batteries perhaps ? Hasn't been an issue and when on solar panels I have power all evening (never use propane heater tho) and recharge during the day. Also have a generator if needed and always starts so .... I'm not sure ?
GenoB
Parker Strip, AZ
Posted: 01/07/20 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
**** Issue Resolved ****
See earlier Posts ...
Old-Biscuit
Verde Valley
Posted: 01/08/20 11:11am Link  |  Quote  |  Print  |  Notify Moderator
YEP......gas valve solenoids
Takes BOTH to hold gas valve open against the spring pressure
Should have had to test ohms earlier but when you stated you had 12VDC ON both I ignored the ohms testing
[emoticon]
Glad you found the issue.!!
GenoB
Parker Strip, AZ
Posted: 01/08/20 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah I did the same thing, got side tracked by the 12 vdc present constant. I had taken a wire and applied 12 vdc to each coil and listened to the hard click and came to the concussing it was working OK and passed on that ... I had thought about checking resistance early on and didn't do it .... Should have ... lol
Tanks for your help anyway, good advise...
