RV.Net Open Roads Forum: Fifth-Wheels: 04 Cougar M301 bhs by keystone
 > 04 Cougar M301 bhs by keystone
Socom
Posted: 01/07/20 07:45am Link  |  Quote  |  Print  |  Notify Moderator
Just bought this 04 cougar travel trailer. Slide out is only working on battery. I disconnected the battery, plugged up to service and slide doesn't work. Is this supposed to be like this or not.Any suggestions on where to start looking for the issue would be helpful.
2012Coleman
Posted: 01/07/20 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
Start by posting your question on the Travel Trailer forum - this one is for help with posting or other forum issues.
Experience without good judgment is worthless; good judgment without experience is still good judgment!
2018 RAM 3500 Big Horn CTD
2018 Grand Design Reflection 303RLS
1492
Arlington, VA
Posted: 01/07/20 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Posting Help and Support
MFL
Midwest
Posted: 01/07/20 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, that is normal, often times the converter alone will not have enough power to operate a slide. It normally takes a well charged battery.
Welcome to the forum! As you can see, there are certain areas to post in, that will get the best replies.
Hope you enjoy the new to you trailer! [emoticon]
Jerry
JKJavelin
Milwaukee, WI
Posted: 01/07/20 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
No need to disconnect the battery. Leaving it connected while plugged in will keep it charged up.
JK
2018 Ram 3500 Laramie Cummins 6.7
2016 Open Range RF316RLS
Titan Disc Brakes
Trailair pinbox
Morryde SRE-4000 w/ wetbolt kit
Demco Hijacker Autoslide 18k
570 watts of Solar
2017- 21 Nights
2018- 75 Nights
2019- 138 Nights
2020- 72 Nights
Socom
Posted: 01/07/20 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks all for the valuable information. I apologise for posting in wrong area and thank you for moving thread to correct place.
Socom
Posted: 01/08/20 06:08am Link  |  Quote  |  Print  |  Notify Moderator
How many times should a fully charged battery move slide in and out before it's dead.
MFL
Midwest
Posted: 01/08/20 06:19am Link  |  Quote  |  Print  |  Notify Moderator
Too many variables to give correct answer. It depends on size of battery, age of battery, how many times it has been at 50 percent charge or less. The battery will quit operating the slide, before it is dead. It will still run some things, but moving a large slideout is a heavy draw. A questionable battery should be replaced.
Jerry
Socom
Posted: 01/08/20 06:23am Link  |  Quote  |  Print  |  Notify Moderator
So best case scenario charge day before leaving, connect battery at camp site plug into service, move slide out. Keep battery connected. Move slide in when leaving. Worst case have to buy battery while camping to get slide in?
Socom
Posted: 01/08/20 06:25am Link  |  Quote  |  Print  |  Notify Moderator
My other question is about the propane sensor inside the rig. When travel trailer is plugged into service, no propane on rig at all. The sensor for gas inside rig keeps going off every 2-3 mins with load continue ring. I hit test button it stops and will go off again. Again there is no gas hooked up to this rig right now. It is hard wired into rig. Do these go bad and time to replace or is there another issue I'm unaware of?
