RV.Net Open Roads Forum: Solar Panel, Unmarked Pigtails, which is Positive, Negative?
 > Solar Panel, Unmarked Pigtails, which is Positive, Negative?
crcr
US
Posted: 01/07/20 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
I bought 5 solar panels recently, the pigtails on the two HQST solar panels are marked as to positive and negative, but the pigtails on the three Renogy 100w panels are not marked. On the HQST panels, the pigtail with the red band is positive. Would it be the same on these Renogy panels?
Two pics of the pigtails on the Renogy solar panels. Which is positive and which is negative?
GKAbbott
On the road
Posted: 01/07/20 05:05pm Link  |  Quote  |  Print  |  Notify Moderator
Use a VOM to determine polarity.
naturist
Lynchburg, VA
Posted: 01/07/20 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
You will note that they have MC4 connectors on them. Those connectors are one male, the other female. It is impossible to connect them wrong because of the MC4 connectors. That is why they are there in the first place. But also, a VOM will confirm they are wired correctly.
BFL13
Victoria, BC
This says the male clip goes to the female clip on the negative pigtail
http://www.wegosolar.com/products.php?pr........=MC%252dMALE-MC%252d4-Male-Clip-with-Pin
BUT--I would definitely use my voltmeter on the panel pigtails with the panel in the sunlight to be sure. If meter pos is on panel pos, the voltage shows pos, if reversed the voltage has a minus sign ( - )in front of it on the meter's readout.
This is the female clip that connects to the panel's pos male clip it says.
http://www.wegosolar.com/products.php?pr........252dFEMALE-MC%252d4-Female-Clip-with-Pin
Your panel's male clip is marked red, so that all checks out.
* This post was edited 01/07/20 05:53pm by BFL13 *
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
pianotuna
Regina, SK, Canada
Posted: 01/07/20 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
Use a multi meter to check the polarity. Note the voltage on all panels.
Regards, Don
Mike134
Elgin
Posted: 01/07/20 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
use volt meter if it reads + then the red probe is touching the + wire. If it reads - then the red probe is touching the neg. wire
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
Boon Docker
Posted: 01/07/20 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
By looking at the direction of those diodes the pigtail with the red ring is positive.
BFL13
Victoria, BC
Posted: 01/07/20 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
If you use the clips as I linked above, and put them on the wrong wires going to the controller, you can end up with them reversed. Those little monsters take a bit of figuring out. [emoticon]
Once they are on you can't get them off either. The pin grabbers mean once in, they stay in. It is an IQ test. If you fail the IQ test you buy more clips!
JesLookin
Appleton,WI
Posted: 01/07/20 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, red ring is positive, because of connection to the diodes.
2013 Arctic Fox 27-5L
2014 Ram 3500 6.7L CTD, Crew Cab
Near Annett’s Mono Village, Bridgeport, CA
Posted: 01/07/20 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
So much for Renogy making it simple, clear for the solar newbie.
