RV.Net Open Roads Forum: Class A Motorhomes: washer/dryer
 > washer/dryer
old guy
Oregon (pronounced Or e gun)
Posted: 01/08/20 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
I read here some years ago that you should only do laundry while in the CG not while driving down the road. no explanation for this and it has bugged me for years. anyone have an answer for me?
2oldman
Ca
Posted: 01/08/20 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
..ahh, too many snappy answers.
K Charles
Connecticut
Posted: 01/08/20 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
I don't have on but I bet it would work fine if you didn't fill the gray tank or run out of water. How much water do you use for a load?
CA Traveler
The Western States
Should be OK.
But my thoughts. Mechanical device bouncing down the road with a load of water and clothes? Probably not designed for that environment. Long gen run times unless you have an inverter in which case more alternator output required. Uses a lot of water. Is someone going to be checking it while moving?
2014 Grand Cherokee Overland
Bob
js218
on the road
Posted: 01/08/20 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
Use mine all the time rolling down the road.
2017 Haulmark 45' Super C 600hp, 12 speed I shift transmission, tandem drive axles, 3 stage engine brake, towing 26' trailer with an 08 explorer inside.
Jim
way2roll
Wilmington NC
Posted: 01/08/20 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
There was a post 3 days ago on this very subject.
Click
ScottG
Bothell Wa.
Posted: 01/08/20 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
I didn't post in the other thread but I would not hesitate.
And I'd run if off an inverter to do so.
* This post was edited 01/08/20 05:02pm by ScottG *
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
PNW_Steve
Pacific Northwet & cold
Posted: 01/08/20 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
I have two rigs with washer and dryer.
I found them fairly useless unless I had full hookups. The water and waste tankage were a severe limitation. Doing a modest amount of laundry DOUBLED our water consumption.
I do a lot of boondocking. That makes the frugal consumption of water and power is necessary. So, laundry in the RV is not very practical for me.
Just my $0.02 [emoticon]
2004.5 Dodge 3500 5.9 Cummins, NV5400, 5" turbo back stainless exhaust, Edger programmer & 22.5 Alcoa's
2002 Forest River 36 5th Wheel (staying home)
1992 Jayco 29 5th Wheel (Mexico veteran & headed back)
2002 "faux" Wanderlodge 40' My new toy....
Ivylog
Blairsville, GA and WPB, FL.
Posted: 01/09/20 05:39am Link  |  Quote  |  Print  |  Notify Moderator
No reason not to, especially if you are going from CG to CG, even with small tanks. Uses 20 gallons and a out of balance load on the spin cycle will put more force on it than any bump.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
[url=https://i.
Bill.Satellite
Full-timer
Posted: 01/09/20 07:01am Link  |  Quote  |  Print  |  Notify Moderator
The Splendide washer can use as little as 9 gallons for a wash. If you add extended wash or rinse cycles it can use up to 16. We have almost never used either of these so the wash cycle is not a big water user.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
 > washer/dryer
