RV.Net Open Roads Forum: Tech Issues: Trailer Tire Speeding Rating??
 > Trailer Tire Speeding Rating??
FrankoToo
New Braunfels, TX
Posted: 01/08/20 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
Recently purchased the new-to-us TT in my sig. For piece of mind, I plan to replace the tires in the very near future. Current tires are Rainier ST235/80R16 Load Range E. Since this is not a large trailer, I'm not overly concerned about overloading. My question is about speed rating. I've searched and read a few posts here but to be honest, the info went over my head. Most ST tires are limited to 65 mph at 80 psi. Would I get anything more by going to an LT tire in the same size or assuming the rims can handle the extra pressure, moving up to a LR F or G tire? It's not my goal to fly down the road doing 80 but know 70 or so is safely doable in parts of the country where higher speeds are allowed. Trailer gross is 11,200, axles rated at 5200. My rims are the only unknown at this point.
Thanks in advance.
FrankoToo
2018 Cruiser Stryker ST2313
2011 Ford F450 6.7L PS 4X4 Crew Cab Lariat
MDKMDK
Canada
Posted: 01/08/20 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
Can't you get new rims that would match the higher rated tires?
Mike.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
FrankoToo
New Braunfels, TX
Posted: 01/08/20 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
That would be worse case scenario but yes, I could always get new rims. Just don't want to spend the money if I don't have too.
BFL13
Victoria, BC
Posted: 01/08/20 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.cruiserrv.com/2018/travel-trailers/stryker-toy-hauler/st-2313/
Looks like you have no weight issues with the current set-up, so as you say, no need for LTs just for that.
Before looking at new wheels, check what PSI you would be using in any LTs to meet the weight. You don't fill them all the way no matter what like you do with STs. So your LT proper PSI could be 65 lbs or less anyway, so current wheels would be ok. Don't forget tongue weight takes some of the weight, which helps.
Once you have your LTs at PSI for the weight, if you can then go faster, IMO it would not be any faster with bigger stronger LTs than any LTs that fit now. AFAIK.
* This post was edited 01/08/20 02:07pm by BFL13 *
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
Old-Biscuit
Verde Valley
Posted: 01/08/20 02:27pm Link  |  Quote  |  Print  |  Notify Moderator
Tire Weight Rating: 3520 Lbs.
Maximum Pressure: 80 PSI
Speed Index: M
'M'----81 mph
Looks like what you got works.
http://www.ecustomrim.com/2-pack-ecustom........railer-tire-st235-80r16-lre-3520-80-psi/
MDKMDK
Canada
Posted: 01/08/20 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
If the higher rated tires were to cause a catastrophic failure with the current wheels, you could be creating a dangerous combination, and your insurer may have a problem with the user mod that created it. If they notice it, of course.
Just sayin'.....
ependydad
Here and there
Posted: 01/08/20 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
The 65mph speed rating for ST tires is outdated information. I want to say it was 2-3 years ago that ST tires started coming with speed ratings stamped on them.
Edit to add, it looks like eTrailer has a question/answer on their site about this:
https://www.etrailer.com/question-152234.html
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
BFL13
Victoria, BC
Posted: 01/08/20 03:15pm Link  |  Quote  |  Print  |  Notify Moderator
OP's TT tongue wt percentage 860/6740= 13%. At GVWR 11,260, 13% is 1,463 so at GVWR, axle wt is 11,260 - 1463 = 9,797 and /4 = 2,450 per tire needed.
OP's STs now 3,520 per tire at 80PSI, but LT would be more like 2,680 at 80PSI (so wheels can take that same as for ST) but still enough for weight but just enough margin for uneven wts per tire as is common with RV loading.
Since newer STs are good for higher speeds, all that would happens is OP loses weight margin, no speed advantage.
wolfe10
Posted: 01/08/20 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.goodyear.com/en-US/tires/endurance/sizes-specs
Click on 235/80R16
Speed rating "N" is 87 MPH: https://www.tiresplus.com/tires/tire-buying-guide/tire-speed-rating/
This is not a comment one way or the other on that particular tire-- I know next to noting about trailer tires. But speed ratings are available.
* This post was edited 01/08/20 03:39pm by wolfe10 *
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Cummins12V98
on the road
Posted: 01/08/20 04:02pm Link  |  Quote  |  Print  |  Notify Moderator
GY ENDURANCE in same size and load rating, never look back!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
