RV.Net Open Roads Forum: How much 5th Wheel can I tow with my truck
 > How much 5th Wheel can I tow with my truck
BarneyS
S.E. Lower Michigan
Posted: 01/08/20 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
RobWNY wrote:
Thanks for everyone's input so far. I'll look at 5th wheels 11000-12000LB with a Pin weight of 25% or less. I should be ok then. I'm looking forward to the Tampa show. I've been to a couple big shows up North but never one that advertises having trams to get people around if needed. It must be huge!
You will really enjoy the Tampa show! We went every year for about 15 years or so. Yes, they have a couple or three "trains" that run a fixed route around the show in the streets along with all the people. Often, if you are pressed for time, you are better taking the hike rather than the tram.
The show is huge. The ticket is good for two days and you will certainly need both full days to see all of it. We never did get all the way around. There are ample places to sit for a bit to rest if needed though. All in all, a fun place to go. Hope you enjoy your visit! [emoticon]
Barney
Not towing now.
RobWNY
Jamestown, NY
Posted: 01/08/20 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
Barney
Thanks Barney. This will be something to see. I can't wait!
If God didn't want us to eat cows, he wouldn't have made them out of Steak and Cheese.
Life is a lot like a baseball pitch. Sometimes you get a fast ball down the middle of the plate and sometimes you get a curve ball in the dirt.
laknox
Arizona
Posted: 01/08/20 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
RobWNY wrote:
Currently I have a Forest River Hemisphere GLX that weighs in the neighborhood of 8500LB dry and about 9500LB loaded. I do not travel with water other than a couple of gallons in the black tank to slosh around. It tows fine and my truck handles it with ease but I'm not very happy with it (poorly and cheaply built). I'm beginning to look at new 5th Wheels but I have no idea what my truck can handle and we all know how a dealer will tell you anything to make a sale. I'm not in a position to change trucks for another three years so I have to stick with the truck I have. I understand that a Dually Diesel is a preferable tow vehicle but not in the cards for me right now. As for the math, everything gets so confusing to me that I need some help. Can someone please give me an idea of the dry weight and max weight of a 5th wheel I should be looking at? Also, what else should I be paying attention to on the sticker of a new 5th wheel? I know I need to look at Pin weight but what else? I'll be adding the same amount of stuff I carry in the rig I have now so please keep that in mind too. We're going to the Tampa RV Supershow on January 16th to browse. Below are the specs of my truck. Thank you for any help you can give me.
From the manual
2017 Ram Crew Cab with 6'6" box. 6.4 Hemi with 3.73 rear end GVWR 10,800 Max Payload 4010LB GCWR 19,900 Max Trailer Weight 12,640
From the Stickers on my truck
GAWR Front 5500LB GAWR Rear 7000LB Max Payload 3900LB
My weight additions
Me 225LB Wife 130LB Spray in Bed Liner 50LB Folding Tonneau Cover 60LB 31 Gallon tank = 186LB when full. B&W Patriot 16K hitch with rails weighs about 175LB total. Then figure I'm going to be adding "Stuff", about 1000LB.
If I forgot anything let me know please and Thank you!
Does that 1,000 lbs of "stuff" go in the truck or in the trailer or split between? Seems a lot to carry in the truck alone...
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
laknox
Arizona
Posted: 01/08/20 09:19pm Link  |  Quote  |  Print  |  Notify Moderator
Coach-man wrote:
OK, a 5th wheel is not a “trailer” and it is not have anything to do with “how much can my truck tow”! A couple of years ago, they had a ½ ton Toyota towing the space shuttle! A 5th wheel puts approximately 25% of its loaded weight on your rear axel. You understand, it is loaded weight, with water, propane, food, beverages, clothes, even batteries are not included with “published dry weight figures”. Also, note that your weight capacity on the trucks door sticker does not take into account gasoline, gear, 5th wheel hitch, and passengers! Subtract weight of passengers, (use 200 pounds each), fuel, weight of hitch from your weight capacity. Then take 25% of the published dry weight of the 5th wheel, and add propane, dual 30 gallon tanks about 120 pounds, clothes food and gear add about 1,500 pounds. Water would be a little tricky, depends on how much you plan to carry, figure 7.5 pounds per gallon, I used to travel with only 10 gallons fill when I got to the site. Also, where the tank is, if behind the rear axel it could subtract weight, in front it would add! Finally, add that all up, and 25% of that total would be in the bed of the truck, how does that add up to the “adjusted” capacity? If that “fits” you should be ok, front rear axel weights can only be determined using scales, which you should do after everything is set up! Good luck, enjoy your new rig!
Last I knew, a truck's weight placard includs full fuel and a 150lb driver. I know that Jayco's cango placard includes full propane and 1 battery.
Lyle
zcookiemonstar
Midwest
Posted: 01/08/20 11:16pm Link  |  Quote  |  Print  |  Notify Moderator
Wow you made the biggest weight mistake ever. You publicly listed your wife's weight!
RobWNY
Jamestown, NY
Posted: 01/09/20 06:09am Link  |  Quote  |  Print  |  Notify Moderator
laknox wrote:
From the manual
My weight additions
Lyle
The 1000LB of stuff is mostly in the trailer. Maybe 100LB extra pounds in the truck so 900LB in the trailer
RobWNY
Jamestown, NY
Posted: 01/09/20 06:13am Link  |  Quote  |  Print  |  Notify Moderator
LOL You should hear what she says about me!
Coach-man
Posted: 01/09/20 07:33am Link  |  Quote  |  Print  |  Notify Moderator
Lyle
Lyle, Not sure if they changed that! Always dry weights, for both the truck as well as the trailer! That way everything is equal. What driver weighs 150 lbs? Propane, 20 gallons, 30 gallons? 40 gallons? How many tanks ? One battery, or 2 6 volt golf cart batteries, Trailers do no ship with batteries in them, the dealer installs the batter(s)! Are you a full timer, or just a weekender with a couple of 6 packs and a ham sandwich! Way too many variables! By listing the dry weight, you can easily customize the weight by adding your actual!
laknox
Arizona
Posted: 01/09/20 08:34am Link  |  Quote  |  Print  |  Notify Moderator
RobWNY wrote:
laknox wrote:
From the manual
My weight additions
Lyle
OK, so the FW will carry the majority of that weight, so figure 350 lbs of the 1,000 lbs (100 lbs + 250 lbs {25% pin}) that might go on the truck. I agree that a 12k max GVW rig would really be all you'd want to look for. Not knowing how you camp, or how frequently, I'd look at something like the KZ Durango 1500 (if used) or Durango Half-Ton. The current Half-Ton line has one model at 11,750 GVW and another at 11,995 GVW. 2 are 9k GVW and the other 4 in the line are 10.5k GVW. My '17 1500 model is one of the 10.5k GVW rigs and my '02 Duramax 2500HD handles it just fine.
Lyle
laknox
Arizona
Posted: 01/09/20 08:43am Link  |  Quote  |  Print  |  Notify Moderator
Coach-man wrote:
Lyle
I'm talking the placard placed on the truck/FW at the factory, that shows the cargo capacity for that =specific= unit. Industry standard was to show trucks' payload as net of all options plus a 150 lb driver and a full fuel tank. When I was shopping for a new FW several years ago, I looked at any number of Jaycos, and every placard I saw, specifically stated that the net cargo included full propane tanks FOR THAT UNIT and 1 battery (this is a pretty standard # for any "marine" 12v battery, within a few lbs.). It also listed the weight of a full fresh water load, but it was not calc'd into the net CCC. Again, this was specific to THAT unit. You make any changes after the FW's manufactured, then that's on =you= to figure out. I'll look at my KZ next time I'm out and see what it, specifically, says about cargo.
Lyle
