RV.Net Open Roads Forum: Class A Motorhomes: Front suspention
Gjac
Milford, CT
Posted: 01/13/20 07:29am Link  |  Quote  |  Print  |  Notify Moderator
Check your ride height first before changing anything. Just measure the gap between the upper A arm and the stop right below it you should have about 1.5 ins or more. If the A Arm is resting on the bumper stop with no space in between I would replace them with new HD springs. If you have some space you may get away with just adding new air bags. How many miles are on the MH? The bags will only add another 500 Lbs capacity when fully inflated. As others have said new shocks won't increase the ride height.
4x4van
California
Posted: 01/14/20 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
myface wrote:
I told the guy about the springs and he said that shocks will raise the front.
Find a different "guy" to give your money to. Anyone who says that shocks will raise your vehicle is lying or stupid. Your shocks may also be shot, but they will have no effect on ride height, only damping.
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R (2), '85 BW200, '07 TRX400EX, '12 Husky TE310
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II, '95 FX1
myface
Posted: 01/15/20 10:01am Link  |  Quote  |  Print  |  Notify Moderator
I got "brave" and crawl under front to measure the distance from A to bumper. It is less that 1.5. I guess that my coils are weak. No I got another challenge - find repair shop that will not charge me arms and legs. I did order the air bags too. That guy from that shop never called me back -good.
myface
Posted: 01/15/20 10:04am Link  |  Quote  |  Print  |  Notify Moderator
I do not want to drive 25mil to near scale. Can I just buy the 6.000lbs springs?. That what my sticker said or should I buy 3.000?.
Gjac
Milford, CT
Posted: 01/15/20 11:05am Link  |  Quote  |  Print  |  Notify Moderator
How much less than 1.5 ins are they? 1.25 in or.5 in? How many miles on the MH? I would either use the HD springs or the bags not both.
myface
Posted: 01/15/20 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
1.25 and 58.000. I saw a springs for $360 pair with 6000lbs.
wolfe10
Posted: 01/15/20 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.hendersonslineup.com/supersteer-products
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
myface
Posted: 01/15/20 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
That what I am planing to get
Gjac
Milford, CT
Posted: 01/15/20 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
Your MH is short probably lighter than many of us that installed the HD Henderson springs.You already ordered the air bags, they will increase your ride height. I would try them first seeing you already paid for them. You really need to know what your front axle weighs, a spring that is too stiff will put a lot more pressure on that upper A arm than it was designed to take, which is only stamped steel and over time can cause fatigue cracks in that arm. Also how are you checking how level your MH sits ?
myface
Posted: 01/16/20 05:26am Link  |  Quote  |  Print  |  Notify Moderator
Visually is low and then when I hit a bump or dip in a road it rub my front tire. Going across a bridge is nightmare - bunch of bumps. After I put a bags in springs, I will take it to a scale. Right now is not good to drive.
