RV.Net Open Roads Forum: Tech Issues: Corrugated underbelly
 > Corrugated underbelly
brn2romethewest
Central Texas
Posted: 01/08/20 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
Hello folks!
I have a fifth wheel trailer that has a one piece corrugated plastic underbelly that needs replacing. The size is 67.75" x 17'. I have found some manufactured by RecPro but it looks kind of thin.
1. Does anyone know where I can purchase some from another manufacturer?
2. Has anyone used the 1/8" thick stuff from RecPro?
Thanks in advance,
Greg
2004 KZ Durango 275RK,
2006 Dodge RAM 3500 (Big Hips edition)
agesilaus
North Florida
Posted: 01/08/20 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
Just use Coroplast which is what recent RV's use. You may be able to get it at a local sign company and small pieces at hobby stores. Or get Home Depot or Lowes to order big sheets. It;s the stuff politicians make their street signs out of. You can get it in black which is the usual RV belly color.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
bucky
Raleigh metro
Posted: 01/09/20 04:43am Link  |  Quote  |  Print  |  Notify Moderator
I bought a 4' x 8' piece at Home Depot recently.
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
Dave H M
IL
Posted: 01/09/20 05:49am Link  |  Quote  |  Print  |  Notify Moderator
I bought a 4X8 sheet at a sign shop recently.
TurnThePage
North ID
Posted: 01/09/20 11:38am Link  |  Quote  |  Print  |  Notify Moderator
Like the others, I've purchased 4x8' sheets at several suppliers here in the Spokane area. Cut it to size, and use a little Gorilla Tape on the seams. When I added corroplast to my trailer, I supported it with several strips of angle aluminum between the frame rails.
2015 Ram 1500
2004 Pioneer 18T6
brn2romethewest
Central Texas
Posted: 01/09/20 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you All for the replies. I really want a long sheet. I am aware of what coroplast is. Was hoping someone knew where to purchase a long piece like 17' long.
Greg
TurnThePage
North ID
Posted: 01/09/20 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
The only places I see it used is at RV manufacturing facilities. Probably start there. Maybe a local RV shop could guide you to a source.
shepfly
NW Ohio
Posted: 01/09/20 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
RV manufacturers buy it in large rolls (36" or larger diameter) and cut to fit. Try surplus dealers in Elkhart, Ind. You might try Bontragers Surplus RV Supplies , of White Pigeon, Mich. Just north of Elkhart. Phone: 866-483-7017, Shipping wt would be low, but oversize charge. Dave
