RV.Net Open Roads Forum: Dinghy Towing: Air brakes on Towed
Search only in Dinghy Towing
 > Air brakes on Towed
William B
On the road
Posted: 01/11/20 04:16am Link  |  Quote  |  Print  |  Notify Moderator
Bill.Satellite wrote:
M&G is great and we have used their system on 4 different tow vehicles over the last 20 years. However, they are limited by the number of vehicles it fits. The folks that have installed my M&G's recommend Air Force 1 for the other vehicles.
I had the normal M&G system on my 2014 Ram 1500, but when I got the new 2019 Ram 1500, there isn't enough room at the brake master cylinder for the original system, but they have another system that uses a cylinder mounted in the engine compartment that pulls the brake pedal, still hooks up and operates exactly the same way, but fits way more vehicles.
Full timing since 2004
2007 Holiday Rambler Navigator 45' DD Series 60
2019 Dodge Ram 1500 Limited
Our Blog
JoeH
Apollo Beach,FL
Posted: 01/11/20 06:29am Link  |  Quote  |  Print  |  Notify Moderator
I've been using a M&G for the last 5 years. Initial installation took me an hour or so. after that, it's just hook up the air line and go.
Joe
2013 Dutch Star 4338- all electric
Toad is 2015 F-150 with bikes,kayaks and Harley aboard
hypoxia
Arizona
Posted: 01/11/20 06:32am Link  |  Quote  |  Print  |  Notify Moderator
Executive wrote:
Why not simply get the ReadyBrake/ReadyBrute?? Nothing to add, nothing to subtract. Just hook it and go. Easiest system there is and nothing hooked to the toad..I've had mine for 10 years.....Dennis
Ready/Brute
I am not a fan of surge brakes with an engine brake. Going down a hill the Ready Brake will be applying toad brakes constantly. They will be warm/hot on a long descent when I have not touched the service brakes.
Jim
2007 Monaco Signature Noble III ISX 600HP
bjbear
Cold Lake, AB, Can
Posted: 01/11/20 07:45am Link  |  Quote  |  Print  |  Notify Moderator
wa8yxm wrote:
dodge guy wrote:
My buddy has the Brake Buddy. Install is easy, just plug it into the power outlet, hookup and he monitor/control box in the MH, watch that it connects and your all done. It's a simple system and you can easily move it between vehicles, unlike you system that is only for the 1 car. I'm planning on getting a newer vehicle and will then have 2 available toads. ThenBrake Buddy will be perfect for that.
As I said good if you have a "Fleet" (2 is a fleet though in the example I think I used 20) .
But every time you put it in the driver's seat that is an install and if you mess up it can total the car's brakes (happened to me on a different system the dealer messed up the install on.. When will I learn to do it or at least check it myself).
and over time that is a lot of work. plus I've spoken to folks who confirmed they said "Oh forget it" for a short trip.. Murphy's law says that's when someone will run out in front of you and SPLAT.
With the M&G or the US-Gear system I had or any of the other fully installed leave 'em in place all the time you just plug it in (if that) 1-2 seconds and it's live.. Some of them you don't even do that.
Mark me down as another Brake Buddy fan. Have been using it for close to 10 years. Very easy and straight forward to install. You would have to be totally incompetant to mess it up. Never felt like leaving it off, even for short drives. Have changed towed vehicle 3 times and the switch over was easy (had to run light setup anyway so adding a 12V charge line and breakaway was not difficult).
2006 Monaco Camelot 42-DSQ
09 Blazer 20' Covered Trailer
Toad - 2019 Wrangler JL Rubicon Unlimited
My Website
way2roll
Wilmington NC
Posted: 01/11/20 10:15am Link  |  Quote  |  Print  |  Notify Moderator
hypoxia wrote:
Ready/Brute
That's not really true, We have the ready brute elite and I've wondered on long descents if the toad brakes heat up with the engine brake on, so I stopped once after a downhill and checked, they were warm but not overly hot. The force required to active the brakes completely comes from stopping the MH, or quickly changing the speed of the MH relative to the car. Down a hill with the engine brake on isn't enough of a difference in speed to push the surge all the way, until you brake. Which is the way it's supposed to work. The car brakes when you brake otherwise the speed is relative to yours. In the 6 years we've been towing our CRV with the ready brute system we have not had to change pads any more frequently than not towing.
2020 F350 STX
2020 FR Cedar Ridge Silverback 29rw
RLS7201
Posted: 01/11/20 11:04am Link  |  Quote  |  Print  |  Notify Moderator
X2 bjbear
Also the Brake Buddy does not install in the seat (geesh!) is sits on the floor in front of the driver's seat. No wonder you had a problem.
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
hypoxia
Arizona
Posted: 01/12/20 06:25am Link  |  Quote  |  Print  |  Notify Moderator
way2roll wrote:
hypoxia wrote:
Ready/Brute
I'm pretty sure you just agreed with me....[emoticon]
way2roll
Wilmington NC
Posted: 01/12/20 08:56am Link  |  Quote  |  Print  |  Notify Moderator
hypoxia wrote:
way2roll wrote:
hypoxia wrote:
Ready/Brute
Pretty sure I didn't. Don't cut snippets of a post that you think offers some evidence to your incorrect assumptions, read the whole post. Any brakes or wheels would be warm to the touch under most any conditions. If they were overheating you wouldn't be able to touch them at all. Don't make posts where you don't know what you are talking about and then troll the person correcting you who has real world experience. You can try and pose like you know what you are talking about but myself and thousands of others who have this system know differently. If you want to discuss the matter further, PM me. Happy to give you my number to discuss it.
slickest1
canada
Posted: 01/12/20 11:36pm Link  |  Quote  |  Print  |  Notify Moderator
I too have used the ready brake system for 10 years and have descended alot of long hills with my exhaust brake on and never have had hot brakes on the toad. Warm yes but not hot. It does what it is supposed to do.
1998 Holiday Rambler Imperial 40 ft.
Dennis and Marcie and Pup the Jack Russell
gfs1943
Whitney, Texas
Posted: 01/15/20 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
way2roll wrote:
hypoxia wrote:
Ready/Brute
This is the correct info. The ReadyBrake does not cause my tires or brakes to get hot. I've been using this system for almost seven years, and have ZERO problems with it.
I've never had another braking system for the toad, so I can't say what's good and what's a lot of trouble. I just know that the ReadyBrute/ReadyBrake system is great.
gfs1943
USAF, Retired (1962 - 1983)
2006 Monaco Diplomat 40PRQ
2006 Honda CR-V
