RV.Net Open Roads Forum: Tech Issues: Great new electrical connectors
 > Great new electrical connectors
agesilaus
North Florida
Posted: 01/09/20 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
I've been trying, painfully to splice a new 120V line into an existing line with very little slack and in tight cramped quarters under the sink. I finally decided to swing by HD to see if they had better connectors for a 3 wire connection and found Pushin 3 way
And are they great just push the skinned bare wire end into the connector and it locks it down. Keep these in mind if you are doing any wiring work. They come in 2, 3 and 4 way and maybe 6 way but that may be 2 ganged 3 ways. Works on 12 gauge and 14 gauge Romex.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
Near Annett’s Mono Village, Bridgeport, CA
Posted: 01/09/20 02:02pm Link  |  Quote  |  Print  |  Notify Moderator
I saw those couple of months ago. Glad to hear they work! TY
Cummins12V98
on the road
Posted: 01/09/20 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
Been around for several years. They work but I prefer a nicely hand tightened wire nut.
These connectors have a very small contact area of metal to conductor.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
enblethen
Moses Lake, WA
Posted: 01/09/20 02:49pm Link  |  Quote  |  Print  |  Notify Moderator
They use the same style of jab in connector terminals on some switches and receptacles. Less then desireable connection.
Rated for different gauges of wire but may not work well with small and large wire.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
gbopp
The Keystone State
Posted: 01/09/20 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
I've been looking at the Wago Lever-Nuts, they have a small lever to lock the wires in place.
I'm debating if I want to try them on some projects.
They should be convenient for tight spaces.
Keep us updated on how well yours work.
delwhjr
TX
Posted: 01/09/20 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
I have used the In-Sure connectors for a while now for low voltage and electrical connections. They have worked perfectly in all situations so far. They hold tightly and are so easy to use.
I have just recently started experimenting with the WAGO Lever-Nuts and so far have nothing but good things to say about them. You can go on WAGOs website and request samples if you want to play around with them.
The one thing I like best is being able to see the connection and know it is completely made between the wire and device.
2019 F250 Crew 4x4 6.2
2019 Rockwood UltraLite 2608BSD
time2roll
Posted: 01/09/20 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
I believe these are rated by code to allow to be covered in a wall without a J-box. In essence rated same as continuous wire by code.
675w Solar pictures back up
enblethen
Moses Lake, WA
Posted: 01/09/20 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
You would have to give your code reference
enblethen
Moses Lake, WA
Posted: 01/09/20 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
Will add that the connectors allowed to be buried in the wall contain the outer jacket and conductors within one case, not individual ones.
time2roll
Posted: 01/09/20 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have an example to compare?
