RV.Net Open Roads Forum: Towing: Difference in receiver styles
Search only in Towing
Open Roads Forum  >  Towing
 > Difference in receiver styles
LoudRam
Southern NJ
Posted: 01/09/20 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
I just bought a 2019 Ram 1500 classic and it doesn't have a receiver so I need to put one on. What is the difference in these styles? I understand the class difference and I'm still debating on whether to use a class 3 or 4 but I can't find any info on the style difference. Both styles can be found in class 3 and 4.
* This post was edited 01/09/20 03:14pm by LoudRam *
Todd
Desert Storm Vet (US Navy)
2019 1500 Classic Quad Cab Express 4X4 5.7 Hemi 3.92
2018 Dutchmen Aspen Trail 2880RKS
If you can read this thank a teacher
If you can read this in english thank a vet
cavie
Posted: 01/09/20 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
It's not a matter of style. The class is determined by the weight of what you intend to tow.
K Charles
Connecticut
Posted: 01/09/20 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
I don think you can use a WD hitch with that little thing on the bottom of your picture.
Monterey, CA
Posted: 01/09/20 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
Isn’t Class III limited to 800 pounds of hitch weight where IV is a thousand? Pretty easy to hit 800 pounds. Max hitch weight on the Silverado is 1,250.
LoudRam
Southern NJ
Posted: 01/09/20 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
Some you can. It depends on the receiver itself. The Mopar one like that says it has a limit of 5000/500 without a WD hitch and 12000/1200 with one.
Mopar receiver
I use an Equalizer WD hitch.
* This post was last edited 01/10/20 03:47am by LoudRam *   View edit history
bikendan
Camano Island, Wash.
Posted: 01/10/20 01:51am Link  |  Quote  |  Print  |  Notify Moderator
i gotta ask, if your Ram didn't come with a receiver, it must not have the factory tow package, correct? therefore did you have a brake controller and its wiring installed and a trans cooler installed?
Also your combo pic doesn't seem to show that you're using a WDH since i don't see one in the pic and your Ram has a lot of rear sag.
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
LoudRam
Southern NJ
Posted: 01/10/20 03:26am Link  |  Quote  |  Print  |  Notify Moderator
It is pre-wired and has a trans cooler. I made sure of that. I made them get me a build sheet for the truck. And yes I am using an Equalizer WD hitch. That pic is deceiving, the rear sag isn't that bad, it's actually level and that's my old truck not my new one. And yes I have a brake controller. I took my P3 out of my old truck. I have it all under control. I just need to install a receiver and order a new harness for my brake controller and mount it.
* This post was last edited 01/10/20 04:57am by LoudRam *   View edit history
dodge guy
Bartlett IL
Posted: 01/10/20 05:59am Link  |  Quote  |  Print  |  Notify Moderator
The bottom one is the way to go! It bolts to the cross tube that the factory receiver is bolted too. No need for the complete add on one, it's going to hang lower and reduce ground clearance.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Posted: 01/10/20 08:56am Link  |  Quote  |  Print  |  Notify Moderator
So, it appears that there is already a frame mounted cross "tube" on the trucks that come with no receiver hitch installed? Seems strange but mfgs do strange things.
Personally, even though the little bolt class IV is rated 1000/10000, I'd spend the $150 vs $60 and just get a real frame mounted class V receiver.
If for no other reason than the small one ties into the bumper and the cross tube and I wouldn't want a hitch tied to the truck bumper.
For me, this is not a good place to save $100.
What's strange, is Hemi with 3.92s and no OE trailer hitch. Mfgs sure do weird things sometimes.
philh
Belleville MI
Posted: 01/10/20 09:37am Link  |  Quote  |  Print  |  Notify Moderator
Probably never tested that engine with trailer towing. My RT Charger was capable of 3800 lbs, and yet the SRT had no tow rating. Funny thing, later models had a much reduced trailer tow capability. rumor was, they never believed anybody would actually tow anything that heavy. It towed fine in the midwest [emoticon]
